Results 1 to 3 of 3
    kalex's Avatar
    Posts
    Global Posts
    728 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Original 2.3.4
    Default Roaming wifi network connectivity issue with Nexus 4. Help requested
    I have a weird problem. i recently moved into 3 floor townhouse and noticed a weird issue with my Nexus 4. I created roaming wifi network consisting of Actiontec MI424WR-GEN2 Revision F router with wifi enabled and apple airport express n version. I have created same ssid on both actiontec and airport express with same password. Actiontec is on channel 11 and airport express is on channel 5. Problem i'm having is that my nexus 4 refuses to transfer from one access point to another one. I have few areas where actiontec is pretty much dead on terms of coverage but airport express is fine and has very good signal. I also have a laptop that seems to transfer fine. Did i misconfigure something on my nexus 4 or on my roaming wifi network setup? trying to figure this out and can't
    any help is appreciated
    Alex
  2. #2
    N4Newbie's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Roaming wifi network connectivity issue with Nexus 4. Help requested
    I think trying to run two WiFi routers with the same SSID is a no-no...
    Depending on your situation, you might be better off with one router and a range extender, like these: range extender - Best Buy
    kalex's Avatar
    Posts
    Global Posts
    728 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Original 2.3.4
    i'm following roaming network guide which actually says to create same ssid and password. Wi-Fi base stations: Setting up and configuring a roaming network (802.11 a/b/g/n)
  1. Network Issues with Nexus 7
    By Ralph_Wiggum in forum Google Nexus 7 Tablet (2012)
    Last Post: 08-01-2012, 08:32 PM
  2. Wifi connects but "Network Connection Issues"
    By chappo2000 in forum Sprint Galaxy S3
    Last Post: 07-23-2012, 05:52 AM
  3. Verizon Rep Says Nationwide Connectivity Issue with Nexus Only
    By 10001110101 in forum Verizon Galaxy Nexus
    Last Post: 02-02-2012, 09:11 PM
  4. Has the wifi / network connection issues been fixed
    By motionxxusxx#IM in forum AT&T ATRIX
    Last Post: 04-14-2011, 08:44 PM
  5. Connectivity issues with Wireless Tether
    By P7M8 in forum Android Apps
    Last Post: 08-13-2010, 09:34 PM
