1. daniel2744's Avatar
    So I previously had YouMail on my nexus 4 8 gb and it worked perfectly. Now since I got my 16gb nexus 4 it doesn't seem to work. When someone calls me they get a message saying that they cant leave a message. Anyone have any ideas?
    Sent from my Nexus 10 using Android Central Forums
    01-27-2013 10:34 PM
  2. still1's Avatar
    I dont know how youmail works but youmail should have a voicemal number you have to configure.
    open phone icon-->Menu-->Settings-->Call forwarding-->
    edit the three number you see to youmail number (Confirmed to work with google voice number. I had the same issue).
    or
    open phone icon-->Menu-->Settings-->voicemail-->service-->and select youmail
    and then click setup if you want to setup
    01-28-2013 10:49 AM
  3. kmcochran's Avatar
    How did you get Youmail working? I had it on my previous phone when I was with Sprint, but couldn't get it to work with Straight Talk. I had to switch to Google Voice.
    Juli83USMC likes this.
    01-28-2013 11:23 AM
  4. YaSo's Avatar
    According to T-Mobile, third party voicemail services don't work on Monthly 4g. I got my MyTouch 4G on 'FlexPay' and visual voicemail worked then. Later, after getting a bunch of messages from T-Mo saying that FlexPay was being phased out and I had to switch to Monthly 4g, the voicemail system operated like my old T-Mo Nokia candybar phones. I soon tried to use the Youmail app, but never got it to work. Youmail says that it may not work with some pre-paid plans, which may be how they see StraightTalk on the network.
    01-29-2013 01:01 PM
  5. daniel2744's Avatar
    I'm on T-Mobile. I'm on a value plan. Its just weird cause it worked good until i got my new nexus 4 a few weeks ago but i just went back to T-Mobile voicemail. i just saw that they have visual voicemail so i'm going to try that out for awhile and see how it works.
    01-29-2013 02:25 PM
  6. YaSo's Avatar
    If visual voicemail works on your T-Mo account, then I would think Youmail should work as well.
    01-29-2013 05:07 PM
  7. daniel2744's Avatar
    It did work on my T-Mobile account with my old nexus 4. it just happens that with my new nexus 4 it doesn't work and i followed all the same steps i did the first day. just weird idk
    01-29-2013 08:40 PM
  8. dtele's Avatar
    Click on the "phone" icon click the 3 small squares click on settings scroll down to Call fowarding, I entered Foward when Busy +13478966996, the same for Foward when unanswered, and the same for Foward when unreachable. I am on at&t , but the set up should be the same.
    planoman likes this.
    02-09-2013 07:38 PM
  9. planoman's Avatar
    I had tried to set it up and it would always get an error when trying to send the code from the dialer. I manually entered the numbers above and they worked! I am also on ATT.
    Now I am using you mail and have VVM on my Nexus 4.
    02-09-2013 11:19 PM
  10. Focht3's Avatar
    I set up Youmail on my Nexus 5 with Android 4.4.2, and had lots of problems. I eventually removed Youmail, and my phone began working properly. Is Youmail compatible with Android 4.4.2?
    03-07-2014 12:05 PM
  1. problem with Youmail
    By hmfoster in forum Verizon HTC Thunderbolt
    Last Post: 06-03-2012, 06:19 PM
  2. Replies: 4
    Last Post: 03-05-2011, 08:38 AM
  3. Sprint Hero has text messaging problem!
    By maxfire05#AC in forum HTC Hero
    Last Post: 10-10-2009, 10:49 AM
  4. FreeRunner cupcake... teething problems
    By Thorney in forum General Help and How To
    Last Post: 09-05-2009, 12:41 AM
  5. problem with google sign in: password not valid
    By sonali in forum T-Mobile G1
    Last Post: 06-20-2009, 10:39 AM
