heard there was a problem with speedtest on Nexus 4 but that should've been patched. Maybe bad APN?
Just got my Nexus today and was getting crappy speeds. Turned to my brother and said how I'm getting rid of it. Phone must of heard me cause then if gave me this in Brooklyn:
http://img.tapatalk.com/d/13/02/03/ja9y5a2y.jpg
The speed test app on WiFi it works great. When I use the cell network I get this.View attachment 58755
I've read about APNs but I'm clueless about what they mean or how to change them.
why would you not get a Nexus device?
Do a search on APN settings and make the changes to the ones listed for your carrier.
I'm using the sim from my iphone 4S with AT&T iphone 4S data plan...
had the exact issue you are showing... made the APN changes... and I'm hitting 6 to 10 Mbps avg.
Deleting the proxy settings to work. Thanks for the help. I'm only getting around 3mb down so further tinkering might be needed.
Hello. Based on the "H" in your screen shot, it appears as though you may be using T-Mobile or one of their MVNOs. I am using iWireless with my N4, a T-Mobile affiliate and my data indicator fluctuates back and forth between "H" and "E" depending on the city I am in. According to the coverage map, I should sometimes be in 4g/HSPA while other times I should be in 3G, however I have yet to see a "3G" indicator on my phone. Is this your experience as well, a lack of 3G indicator, on your phone when using T-Mobile towers?
