I got my nexus 4 on Jan 31 and I must say best phone ever, but the problem is sending mms on the solavei network. I tried the apn setting that was post up here and it still doesn't work.... Help plse!!
Printable View
call solaveiQuote:
Originally Posted by Makeittrav [Only registered and activated users can see links. Click Here To Register...]
You need to create a second APN just for the MMS settings.Quote:
I had did that,and it's finally working now thankx
Would you mind posting the exact values you used for both APNs? There's been conflicting information posted in the past, I'd like to test out the settings you've used to correct the issue.Quote:
apn: solavei
Mcc:310
mnc:260
apn type: default
The second one is
apn: solavei
mms: [Only registered and activated users can see links. Click Here To Register...]
mms proxy: 216.155.165.50
mms port: 8080
mcc:316
mnc:260
Authentication type:PAP
It's pretty much the same thing that everyone else is using
FYI, This was clearly a mistake on my part... When I first added the two Solavei APNs I didn't delete the old T-Mobile one that was there originally. MMS didn't work until I deleted that APN even though it wasn't the default anymore.
