Results 1 to 2 of 2
    Default Nexus 4 wifi connectivity and battery issues
    I've had the Nexus 4 for a week now and I've faced quite a few problems already:
    1) My phone doesn't connect to the wifi network (even though the wifi info is saved) until I turn off wifi from the setting and turn it back on. I called up google support and they said that's how the manufacturer designed the phone so you will have to do this every time you move in to a new wifi zone. If you have any complaints about this please contact LG.
    2) The battery life is too short- it hardly lasts 12 hours and that too with minimal use. I asked the guy on the support line how I can improve battery consumption and he's like use the app manager to shut down apps. When I asked him how to get to app manager he's like this is how I do it on my android phone, don't know how you do it on the Nexus 4 cos I haven't used it!!
    3) Quite often when I try to enter the unlock pattern on the lock screen, it doesnt recognize any touch and I have to keep tapping the screen until it finally comes to life.
    4) Apparently android beam on the nexus 4 is not compatible with android beam on the samsung galaxy 3. I tried transferring pics from/to a couple of S3s and it wouldn't accept files from them (or rather it would accept the file but couldn't open them saying "file not found") and when I tried sending one of the S3s accepted it and with the other one I got a msg saying "the recepient's phone does not support transfer of large files").
    I was really excited about my new N4 but now with all these problems I'm quite disappointed- more so after the response I got from the help line. Is anyone else facing similar issues and/or help me fix them?
  2. #2
    Default Re: Nexus 4 wifi connectivity and battery issues
    1) I dont really understand what are your expectations here.. The N4 probably doesnt auto-reconnect when change zone because the wifi isnt constantly scanning the available networks.. which is a good thing.. you know, to save battery.. And it's meant NOT to auto-switch because people expect a stable connection even if they are in a zone with more than one accessible network. That's pretty obvious, in fact.
    2) Disable GPS, NFC and auto-brightness (default is ON) -- TURN OFF WIFI when you leave a Wifi zone! (You may want to put a power widget on your home screen to save clicks.) Do not use Live wallpapers (Like the default one). Do not auto-upload photos on cloud services like Dropbox or Facebook. Stay away from LTE. (I'm an Canada) =)
    3) Try Face Unlock!? =) Or maybe a PIN code.. You may find this less frustrating.
    4) Samsung Galaxy devices have this "souped-up" Android Beam functionality that they boldly called "Galaxy Beam" (or is it S Beam?.. Anyway), which kind of uses BOTH NFC and Wifi Direct to handle big files tranfers such as pictures or videos, but sadly, its a proprietary protocol.
    Not to be mistaken with the regular/REAL Android Beam available on other NFC-enabled Android 4.1+ devices.
    You can beam web links, contact cards.. That kind of short string information. Nothing more than a very few kb's. = Upload (manually) your pics and vids on a cloud service THEN beam the address.
    Hope it helps!
  1. Replies: 13
    Last Post: 01-16-2013, 09:20 AM
  2. Replies: 0
    Last Post: 11-07-2012, 02:57 AM
  3. ICS update a mess? GPS Issues, 3G/4G issues and battery issues.
    By rebelguy in forum Verizon HTC Rezound
    Last Post: 09-09-2012, 01:04 PM
  4. Nexus S, ICS and Battery Issues
    By smckane in forum T-Mobile Nexus S
    Last Post: 04-23-2012, 05:22 PM
  5. Slow EVO and battery issues
    By broadwayblues in forum HTC EVO 4G
    Last Post: 01-29-2011, 03:20 PM
