Re: Newbie battery question
That really should not happen with your phone.. If you go into your quick settings and click on battery, what does the graph look like? Does it show it slowly discharging over night or a sudden drop?
Yeah. Please show us your battery graph. Also, juice defender just turns off your data, which can save some battery life.
Sent from my Nexus 7 using Tapatalk HD
I have seen other posts like this and it is not normal. I usually do not lose any power overnight. I switch to another phone on Monday and do not power up my Nexus 4 until Friday and it loses a bit but minimal battery. I do not use JD or anything like that.
Definitely not normal. I usually lose between 5%-10% overnight which I usually sleep around 8 hours
1 Attachment(s)
[Only registered and activated users can see links. Click Here To Register...]
Here's the screenshot
Thanks in advance
U have some kind of wake lock issue. All the spots where the phone is awake but the screen isn't turning on means something is waking your phone and not letting it into deep sleep I presume. I'd download GSAM battery monitor and CPU spy
