1. ryanr509's Avatar
    Wondering what kind of battery life people are getting on their nexus 4. Whether on wifi or hspa+ and what kind of screen on time u are getting. Here are my latest times pretty much all on WiFi.
    Attached Thumbnails Battery life.-uploadfromtaptalk1360499897733.jpg   Battery life.-uploadfromtaptalk1360499905466.jpg   Battery life.-uploadfromtaptalk1360499912889.jpg
    02-10-2013 06:38 AM
  2. n3wDaddy77's Avatar
    I'm not getting anywhere near that kind of battery performance.
    For some reason I'm consistently seeing Android OS using more of my battery than my screen. I need to read more forum posts to see what people have done about this.
    I'm a moderate user and I turn off Wi-Fi while at the office
    Attached Thumbnails Battery life.-uploadfromtaptalk1360625854586.jpg   Battery life.-uploadfromtaptalk1360625900062.jpg
    02-11-2013 05:53 PM
  3. chubb's Avatar
    Wow. I'm at 41%, 13hrs on charge, and only 1hr 17 minuets of screen time. Battery seems to have gotten worse for me the last few days
    I noticed today that like you Google+ was using a lot of battery, just under 10% for me, and I never use it so I force closed it. Hopefully that will help my battery life. Also maps is the biggest killer of my battery at 18%, hardly ever use maps, so I'm thinking its Google Now keeping maps active.
    02-11-2013 06:46 PM
  4. ryanr509's Avatar
    If you go into maps>settings>location settings and disable report from this device it should help with the maps problem. Also remember my battery life was on WiFi only. If I'm using just HSPA+ I get only about 10hours and 2.5-3hrs screen on time
    chubb likes this.
    02-11-2013 07:32 PM
  5. chubb's Avatar
    Will have to give that a shot. Thanks for the tip!
    02-11-2013 07:41 PM
  6. gone down south's Avatar
    You've had your phone on for 21 hours and still have 20 something percent charge left? By definition your battery is behaving perfectly, stop stressing!
    n3wDaddy77 likes this.
    02-11-2013 07:44 PM
  7. skidmark's Avatar
    If you do this I believe when you open google maps it will not locate your current location. Someone correct me if I am wrong.
    02-11-2013 08:44 PM
  1. Improving Battery Life on Your Android Device
    By ERDude in forum HTC Hero
    Last Post: 09-07-2013, 12:03 AM
  2. Battery life terrible?
    By bilobi in forum T-Mobile G1
    Last Post: 08-09-2013, 10:57 AM
  3. Samsung Moment battery life
    By IIJBII in forum Samsung Moment
    Last Post: 03-21-2012, 08:48 PM
  4. battery life
    By kunak83 in forum Motorola Droid
    Last Post: 11-29-2009, 11:28 AM
  5. Anyone's Battery Life Getting BETTER?
    By chrislitzkow in forum Motorola Droid
    Last Post: 11-20-2009, 11:04 PM
