Results 1 to 16 of 16
- 02-11-2013, 02:16 PM
Thread Author #1
Any way to fix long wait (latency) when first connecting to internet on TMobile with Nexus 4?
If I'm connecting to the internet (in an app or browser) on the Nexus 4 while on TMobile's data connection, if I haven't done that for at least 5 minutes, there's a very long wait before the first connection. Is there any way to speed this up?
Example:
1. Turn on phone while outside
2. Open web browser
3. Go to google.com
4. There's a long 30 second or so wait
5. Click any link, it's a quick connection (and it continues to be quick during the rest of the web surfing) - 02-11-2013, 02:18 PM #2
Re: Any way to fix long wait (latency) when first connecting to internet on TMobile with Nexus 4?
when connecting to mobile data from carrier It only takes me 1-2 seconds to connect.
or are you talking about connection after a reboot? - 02-11-2013, 02:44 PM
Thread Author #3
- 02-11-2013, 02:49 PM #4
It shouldn't be a thirty-second wait. On T-Mobile's networks, your phone idles on 3G while remaining authenticated with the HSPA+ network. When you initiate a data session, your phone then jumps onto HSPA+; the primary reason for this behavior being a reduction in power draw.
Typically the time it takes to acquire an active data connection when stepping up to HSPA+ is between two and six seconds, but it may be affected by signal strength or other factors.Represent yourself well; you never know what might happen. And try out the new Android Central app!
Softbricking be damned. - 02-11-2013, 03:19 PM #5
Mine took 3 seconds. Any chance that you could be close enough to your homes wifi that your phone is trying to figure out how to best send the request, or trying to hit the wifi network, then realizing after 25 seconds or so, that the signal is not strong enough? What happens if you try this while driving around when a recent wifi connection is not part of the equation?
EDIT: You're not running anything like Juice Defender are you?Semper Fi
I love my LG Nexus 4! - 02-11-2013, 03:32 PM #6
- 02-12-2013, 02:24 PM
Thread Author #7
No on both questions. I'm 1/2 mile from my wifi after 5 minutes of walking and I don't use Juice Defender and never have.
And when it happens, there's no wifi icon.
- - - Updated - - -
I'll try that but I don't think that's what's causing this. - 02-12-2013, 03:51 PM #8
Softbricking be damned. - 02-12-2013, 10:46 PM
Thread Author #9
- 02-13-2013, 01:37 AM #10
In that case, the cause likely isn't poor signal strength. For future reference, however, you can go into I believe it is Settings > About > Status and find your signal information there. There really isn't any way to 'verify' that this is causing a problem other than by process of elimination.
At this point I would recommend getting a new SIM if you have not done so already. It should only take a minute to get a new one in a retail store, and hopefully either the provisioning process or the new SIM itself will solve the problem.Represent yourself well; you never know what might happen. And try out the new Android Central app!
Softbricking be damned. - 02-13-2013, 05:39 AM #11
- 02-13-2013, 08:39 AM #12
Have you mucked with your APN settings at all? Added things in that weren't there by default? Before trying a replacement SIM, try resetting your APN to default.
Settings -> More -> Mobile networks -> Access Point Names -> Menu -> Reset to default - 02-13-2013, 08:58 AM #13
- 02-13-2013, 11:13 AM
Thread Author #14
- 02-13-2013, 11:15 AM
Thread Author #15
- 02-13-2013, 11:20 AM
Thread Author #16
Google Nexus 7 shut down when is connected to wifi
By lllll5 in forum Google Nexus 7 TabletReplies: 0Last Post: 10-05-2012, 03:56 PM -
Any pouches that will fit the phone when it has a case on it?
By DubM in forum Samsung Galaxy S3Replies: 8Last Post: 07-17-2012, 10:26 PM -
How many people are starting to lose the hype due to the long wait?
By awesomedeals88 in forum Sprint Epic 4GReplies: 35Last Post: 08-30-2010, 12:05 AM -
What features are you waiting for when it comes to Froyo 2.2?
By CoryBantic in forum HTC EVO 4GReplies: 3Last Post: 07-30-2010, 01:29 PM -
When phone connected to wifi, file sharing with pc?
By rjdangerous in forum General Help and How ToReplies: 2Last Post: 07-02-2010, 07:47 AM
Reply
