Results 1 to 5 of 5
    Default 'Andoid OS' using ALL the battery apparently,
    Ok, up until a couple of days ago, the phone was ok battery wise. Normal usage, I'd be down to somwhere between 50-70% in a day. Looking at the stats they looks something like this -
    With the screen taking most of the battery life, usually lasting me between 3.5-4 hours, which I believe is normal. No issue with that.
    However, randomly, I now have Andoid OS taking up loads of battery. It seems to be a constant slow drain.
    Yesterday I was getting maybe 30% of it used by Andoid OS. Today however it looks like this:
    I'm guessing at this point there'd been maybe 30 mins screen time. Yet it doesn't show up at all. EVERYTHING is showing up as Andoid OS.
    I know there's a bug which needs fixing but I get the impression this is different as nothing else is showing up.
    Any ideas?
    Alex
  2. #2
    Default Re: 'Andoid OS' using ALL the battery apparently,
    Have you installed any apps recently? Maybe one of them is hitting up the system.
    Semper Fi
    I love my LG Nexus 4!
  3. #3
    Nothing constructive to add. Just that it is weird that nothing else shows in the list. Try going to the Apps list in Settings and see if anything there seems to be doing something out of the ordinary. Also, your signal says "h" which seems odd too but maybe you have it set to somehow say Home vs Roaming instead of your type of signal. Good luck.
    Sent from my totally awesome Sprint Galaxy Nexus, even if I don't know all its secrets yet.
    I dont think I've installed anything recently, certainly nothing suspect.
    As for the signal, that's normal on any 3G phone in the UK. H indicates I've got HSPA coverage. It will display either H, 3G, G, or E depending on what data connection I have. In the first one, I'm on wifi so it doesn't show. I assumed all phones did this everywhere tbh, but I'm guessing not.
  5. #5
    Prob a glitch, just reboot, recharge and see if it happens again.
  1. What is using all the 4gb ROM space?
    By zedorda in forum HTC One V
    Last Post: 11-24-2012, 12:21 PM
  2. How do I learn how to use all the features?
    By barskin in forum Samsung Galaxy Note 10.1
    Last Post: 09-23-2012, 11:07 PM
  3. How come the screen is not using all the space on it?
    By Andy847 in forum Samsung Galaxy Note 10.1
    Last Post: 09-20-2012, 09:39 PM
  4. I'm still not used to the battery
    By bed269 in forum Droid RAZR MAXX
    Last Post: 03-04-2012, 10:30 PM
  5. do all the galaxy s series phones use the same battery?
    By XKxRome0ox in forum AT&T Captivate
    Last Post: 09-25-2010, 02:55 AM
