02-19-2013 04:51 PM
40 12
tools
  1. Chimpware's Avatar
    On T-Mobile in NJ I get really long ping times also normally (500 to 800 ms), but have gotten spot results down in the 40 ms range. Speeds here are typically in the 10 - 15 Mbps download and 1 to 3 Mbps upload range. Blows away my AT&T results with my iPhone 4s so much better for me than I did have.
    02-18-2013 07:31 AM
  2. bokeh4me's Avatar
    In my office, which is notorious for lousy cell signals, Speedtest just gave me 15.7 up, 8.1 down and 14ms ping. So far, I have no reason to complain about this phone or TMobile's prepaid plan.
    02-18-2013 08:44 AM
  3. minnemike's Avatar
    This mornings speed test
    ok, I have to know.... is it possible to see a screen shot of your APN settings?
    02-18-2013 08:46 AM
  4. Jeremy8000's Avatar
    T-Mobile always has high pings. But my speeds and service in NYC are outstanding.
    It must just be T-mo in your area, as it's consistantly below 100ms here. But as someone said above, unless you're using it for online gaming you won't really be bothered terribly by it.
    02-18-2013 08:49 AM
  5. bokeh4me's Avatar
    Mike,
    All the settings are stock, I havent changed them a bit, but here's what is set:
    APN epc.tmobile.com
    Proxy not set
    Port not set
    Username not set
    Password not set
    server not set
    MMSC http://mms.msg.eng.t-mobile.com/mms/wapenc
    MMS Proxy not set
    MMS port not set
    MCC 310
    MNC 260
    Authentication type not set
    APN Type default,supl,mms
    APN Protocol IPV4
    APN roaming protocol IPV4
    Bearer unspecified
    So there you have it. Ive tested in Shoreview and Minnetonka both, and getting excellent results.
    minnemike likes this.
    02-18-2013 09:25 AM
  6. PWC Realtor's Avatar
    Screen shot shows your on wifi. Besides theoretical max uploads speeds on HSPA+ is only 5.76 mb/s.
    02-18-2013 09:31 AM
  7. minnemike's Avatar
    Ha! Yeah - turn off wifi and test it.
    I will say though, I am now getting 7 down in my basement - used to only get 5. So, either Tmo has upgraded something here or the 4.2.2 update has done some wonders. I need to try out that speed test across the street from the tower again - maybe I'll get 30!
    02-18-2013 09:49 AM
  8. bokeh4me's Avatar
    wifi off -
    47ms ping
    5.8 up
    28.2 down - still nothing to complain about.
    02-18-2013 10:37 AM
  9. qnet's Avatar
    Never heard of anyone getting up to 25, let alone 30.
    T-Mobile turned on LTE early in MN, maybe?
    27 is the highest I've got but, I was close to a tower.
    Wouldn't matter. The Nexus 4 is not an LTE phone, and the update took away the ability to even put it on LTE.
    I have been reading that the Nexus 4 will indeed be able to access Tmo's LTE network when it comes out. Below is a post from the XDA thread about the guy who got LTE on his Gnote. The poster in the post is not the OP but, says this test is from a Tmo employee testing LTE in K.C. with a Nexus 4.
    xda-developers - View Single Post - T-Mobile LTE already in Kansas City!
    02-18-2013 12:03 PM
  10. DeadpoolJunior's Avatar
    Yeah, you're on Wifi man. Toggle WiFi off and lets see it.
    02-18-2013 12:10 PM
  11. ryanr509's Avatar
    Here's a speed test on T-Mobile prepaid. I'm in an hspa+21 market also. Great speed. But I noticed building penetration sucks compared to my straight talk AT&T Sim card. But the speed of my T-Mobile Sim is about 5-8 times faster which I don't understand because I get better coverage and more bars with AT&T sim
    Attached Thumbnails First speed test Nexus 4 on TMobile-uploadfromtaptalk1361276696550.jpg
    02-19-2013 06:27 AM
  12. minnemike's Avatar
    Just a guess, but I'd assume your Tmo connection is at a faster standard, but your ATT tower is closer.
    02-19-2013 01:26 PM
  13. ryanr509's Avatar
    Yep has to be something. I only get around 2mbps download on AT&T with full bars. And around 350ms pings
    02-19-2013 02:51 PM
  14. minnemike's Avatar
    One thing to note with ATT - you have to be certain you are on a H+ type plan. At 2mbps it looks like you are only enabled up to 3g. I don't know if there is some sort of ATT straight talk limit though.
    02-19-2013 04:44 PM
  15. ryanr509's Avatar
    Ya in not sure either. I get pretty much full bars everywhere and have the apn setting straight talk says to use
    02-19-2013 04:51 PM
40 12
  1. Replies: 15
    Last Post: 02-13-2013, 11:20 AM
  2. Galaxy Nexus LTE Speed Test Video - GN added to Indirect Stores
    By sushiglobster in forum Verizon Galaxy Nexus
    Last Post: 12-03-2011, 12:13 AM
  3. I just found the Function on a mobile speed test site.
    By tehsusenoh in forum Verizon Galaxy Nexus
    Last Post: 07-20-2011, 01:52 AM
  4. I got 4.04 mbps download on the speakeasy speed test
    By tallal565 in forum AT&T Inspire 4G
    Last Post: 04-11-2011, 02:06 PM
  5. atrix vs nexus one speed test
    By Lason in forum AT&T ATRIX
    Last Post: 02-22-2011, 02:05 PM
