Results 1 to 24 of 24
Like Tree2Likes
    Prash7's Avatar
    Posts
    Global Posts
    59 Global Posts
    Default Using a different charger
    Hey all!
    Just got my nexus Was wondering, would it be harmful to use my blackberry charger (just the plug) rather than the LG one? It just fits better into my wall.
    Thanks!
  2. #2
    Chex313's Avatar
    Posts
    Global Posts
    304 Global Posts
    ROM
    4.2 Jelly Bean
    Default Re: Using a different battery
    Quote Originally Posted by Prash7 View Post
    Hey all!
    Just got my nexus Was wondering, would it be harmful to use my blackberry charger (just the plug) rather than the LG one? It just fits better into my wall.Thanks!
    We have no problems. If it charges it your good. If it doesn't like the amount of v or current flow it won't charge.
    Google GN (4.2.2) N4 (4.2.2), iphone 5, Galaxy S2 (PureGNexus ROM ics),N7(4.2.2) AT&T
    Prash7's Avatar
    Posts
    Global Posts
    59 Global Posts
    That's great! Just don't want to wreck the non-removable battery :P
  4. #4
    Chex313's Avatar
    Posts
    Global Posts
    304 Global Posts
    ROM
    4.2 Jelly Bean
    I find that the charger that came with it and the one for the N7 charge the fastest.
    Prash7's Avatar
    Posts
    Global Posts
    59 Global Posts
    Quick question:
    How can I get Google New voice to work when I say "Google [..]"? Android noob here; haven't used it since gingerbread :P
    EDIT: Nvm, needs to be in English USA!
  6. #6
    Greg C's Avatar
    Posts
    Global Posts
    688 Global Posts
    ROM
    Stock Jellybean 4.2.2
    My LG charger died within 2 months. I now use the charger from my Motorola Atrix 4G which has lasted 2 years now.
  7. #7
    I use a Samsung Galaxy S2 charger with mine and it works fine. Takes about the same time to charge as it does with the one included with the Nexus 4.
  8. #8
    Default Re: Using a different charger
    Hey all!
    Thanks!
    If my Android charger is on another floor and I don't feel like going to get it, I'll use my husband's BB charger. Actually, the charger in my bedroom is from my LG phone. I keep the GNex charger on the first floor for easy pulling of the cord if I think I'll need to charge my phone via laptop. Once the law was passed about the universal tips, I don't think you have to worry.
    Sent from my totally awesome Sprint Galaxy Nexus, even if I don't know all its secrets yet.
  9. #9
    NotJustAPhone's Avatar
    Posts
    Global Posts
    10,451 Global Posts
    ROM
    GS3: CleanROM / N4: AOKP
    Thread has been cleaned. Let's keep the discussion civil. There's no need for name calling or insults. If you believe a post is inappropriate, please hit the report button. Thanks.
    Sent from my Galaxy Note II
    Thanked by:
  10. #10
    Tronstar's Avatar
    Posts
    ROM
    AOKP
    My OEM transformer/adapter stopped working within a month. I have used numerous cables and adapters since without any noticable issues.
  11. #11
    I don't think I've ever used the chargers that came with the past 3 phones that I've owned. Never had a problem.
  12. #12
    I went out to my car to try out the old Griffin charger that I bought for an iPhone a few years ago. It works as well.
    Thanked by:
  13. #13
    Check the watt-age/amperage of the charger you want to use. I believe the travel charger that comes with the N4 is 5W 1200mA (= 1.2A). Most phone USB chargers are 5W 1A chargers, but some cheap ones are crap that only identify themselves as a 500mA USB data port (D- and D+ lines aren't shorted together), so will charge the N4 much slower. A good, tablet charger like a 10W 2A charger for the Nexus 7 or Kindle Fire will do fine, the Nexus 4 shouldn't take any more current (the (A)mps part of the equation) than it wants. In my initial tests with Battery Monitor Widget Pro, I've noticed the N4 isn't taking much more than 600mA, even on an ASUS Nexus 7 charger. Couldn't tell you why. [corrected]
    The LG Nexus wireless charger (WCP-400) comes with a big ol' 1800mA adapter, and ... darn ... I can't read what the output is supposed to be without watchmaker's glasses. I suspect the WCP400 uses a fair amount of current powering the inductive charging schtuff.
    But generally if you've got a 5W 1A charger from another phone, it should be fine. Use a good microUSB cable, not some cheap crap. (Yes, it's true. I've found charging performance differs with some cables.)
    iPhone-specific chargers may be wonky. Apple uses a weird protocol where the iDevices look for 2.0V and 2.7V on D- and D+ (if I recall correctly), an Apple device finds that and sucks down up to 1A, but on other chargers (conventional, with D- and D+ shorted), stop at 500mA regardless of what the charger is capable of. Chalk it up to Apple "thinking different." Read: proprietary. :P
    Sent by accident, not using the Android Central app
    Nexus 4 (Mako), Amaze 4G on T-Mobile. Nexus 7 16GB. Google Chromebook (2012 Samsung 16gb). Next stop, a Google flush toilet.
    Did I solve your problem? Hit the Thanks button. Was I just a nuisance? Sorry, can't bat .400 every day.
    Thanked by:
    Prash7
  14. Thread Author  Thread Author    #14
    Prash7's Avatar
    Posts
    Global Posts
    59 Global Posts
    Quote Originally Posted by ChromeJob View Post
    Check the watt-age/amperage of the charger you want to use. I believe the travel charger that comes with the N4 is 5W 1200mA (= 1.2A). Most phone USB chargers are 5W 1A chargers, but some cheap ones are crap that only identify themselves as a 500mA USB data port (D- and D+ lines aren't shorted together), so will charge the N4 much slower. A good, tablet charger like a 10W 2A charger for the Nexus 7 or Kindle Fire will do fine, the Nexus 4 shouldn't take any more current (the (A)mps part of the equation) than it wants. In my initial tests with Battery Monitor Widget Pro, I've noticed the N4 isn't taking much more than 500mA, even on an ASUS Nexus 7 charger. Couldn't tell you why.
    But generally if you've got a 5W 1A charger from another phone, it should be fine. Use a good microUSB cable, not come cheap crap. (Yes, it's true. I've found charging performance differs with some cables.)
    Thank you! Yeah, I've definitely noticed a slower charge with my BB plug. Just read it; output is 750mA! So considerably less than the provided one.
  15. #15
    I have several chargers for my Samsung (original) Galaxy, and keep them scattered around the house and work. Checking one here, it says the output 5.0V, 0.7A. The charger that came with the Nexus says output is 5.0V 1.2A. (I'm glad I have a magnifying glass lying around!) I didn't look, but am assuming the car one is the same.
    That's totally Greek to me! Can someone confirm that this won't hurt the Nexus. If it just charges slower, that is fine for a spare at work.
  16. #16
    Teknojnky's Avatar
    Posts
    Global Posts
    117 Global Posts
    If you have too little milliamps (mA) the phone will not charge. The more mA you have, the faster it will charge. Too much and the battery will get hot.
    That is from my personal experience with my blackberry.
  17. #17
    It's not going to hurt to use a different charger. As long as it doesn't charge too fast and overheat the battery you're fine..
  18. #18
    I used an iPhone charger (the smaller one) and my Nexus did not like it at all. It went into deep sleep and had to use the on + up/down volume buttons to reset it. I'm using the LG charger from now on unless I can find the exact same specs.
  19. #19
    Thanks. I did use the Samsung charger last night and nothing blew up or melted .
    I intend to keep my old phone near the TV to use as a remote for my wireless DVD player. Hmm, just realized that from what was said above, using the Nexus charger on the Samsung might be too much so I'll need to remember to use the right charger for it.
  20. #20
    Morjesta's Avatar
    Posts
    Global Posts
    146 Global Posts
    ROM
    4.0.4
    make sure you use the same mAh, that the LG charger has.
    My girlfriend used an iPad charger to charger her iPhone for awhile and the battery on her iPhone got bloated and had to be changed. I been told that the iPad charger has twice the mAh than the iPhone one.
    just sharing my experience. If i was you ill just stick to the same mAh.
    Output 4.8V @ 1A
    "Designers are the New Rockstars"
  21. #21
    Quote Originally Posted by Morjesta View Post
    Output 4.8V @ 1A
    This is true. The iPad charger is beastly. Mine reads 5.1V 2.1A. Don't think I'll be using that.
  22. #22
    chubb's Avatar
    Posts
    ROM
    Stock Xoom, Nexus 4 AOKP
    I don't use the charger that came with the phone since it died. It worked one time. I use my old Galaxy Nexus charger upstairs, downstairs I use either a HTC Thunderbolt charger , or some Motorola cables I got to my laptop. So far no issues, so I wouldn't worry about it.
  23. #23
    I'm using a charger that came with a cheap Samsung phone that I bought at Walmart. I like it because the cord is long enough for me to keep plugged in and still use my phone. The cord that came with my Nexus 7 is longer than the one that came with my Nexus 4 so I'll just use the shorter one in my car.
  24. #24
    A proper device will not draw more current than it can handle. I use 2A chargers on my Amaze and N4 regularly with no ill effects. Generally what you see printed on the charger is the MAX it's rated for. The phone should only draw what it needs.
    Apple chargers are a different case, I wouldn't mix and match with those.
    // Tapatalk HD for Android - Nexus 7 //
  1. Will using a different charger screw with my battery?
    By mozzarella72 in forum Verizon Galaxy Nexus
    Last Post: 01-14-2012, 03:59 PM
  2. do all the galaxy s series phones use the same battery?
    By XKxRome0ox in forum AT&T Captivate
    Last Post: 09-25-2010, 02:55 AM
  3. Are you going to use a different UI instead of Touchwiz?
    By Nickles0n in forum Sprint Epic 4G
    Last Post: 07-21-2010, 08:50 PM
  4. Replies: 6
    Last Post: 06-22-2010, 07:31 PM
  5. Does the Eris use the same battery as the Incredible?
    By Night Train in forum Verizon Droid Incredible
    Last Post: 05-11-2010, 05:44 PM
