- 03-09-2013, 12:30 AM
Thread Author #1
- 03-09-2013, 02:28 AM #2
Re: How to correctly charge lithium polymer battery
Yes you can charge whenever you want, but you should not let your battery fully discharge. Lithium batteries do best if kept above 20 -30% and below 80%. There is no need to "cycle" the battery by draining it fully and charging it fully, this is actually bad for these batteries as they go into a sleep type mode when discharged for prolonged periods of time and you will probably find yourself unable to charge it at all using the normal charger.
Yes you can charge overnight. Lithium batteries don't like heat, but they have thermal switches built in to stop charging when your battery is charged or when over heated.
Ofcourse this is my opinion, based on what I have been able to hunt down info wise.. with regular use and regular charging your battery should be fine.Thanked by: - 03-09-2013, 03:25 AM #3
Everyone seems to have their own theory about proper battery maintenance, and they're often contradictory. Honestly, I think that unless you're going to hang onto your phone for more than three years, it's unlikely you'll wear your battery out almost no matter what you do (within reason, of course).
How to tell if Nexus 4 Battery is Fully Charged?
By yukichi in forum Google Nexus 4Replies: 5Last Post: 02-02-2013, 08:35 AM -
How to disable charge complete notification
By tmags2 in forum Samsung Galaxy S3Replies: 8Last Post: 07-17-2012, 12:30 PM -
Anyone here know how to fix built-in tablet battery?
By Loey Lee in forum Tablet ChatReplies: 4Last Post: 02-03-2012, 12:27 AM -
How to UNBRAND you Motorola Atrix Battery COVER.
By 4mynikka in forum AT&T ATRIXReplies: 13Last Post: 03-11-2011, 08:17 AM -
Pressing "make calls" from within navigator causes force close...how to correct this?
By evolutionary#ac in forum HTC EVO 4GReplies: 0Last Post: 06-25-2010, 11:08 PM
Reply
