See title. Something like 60-70% of my battery is being drained by Mediaserver on a regular basis. I charge my N4 overnight, take it off the charger at 8am, by 11am its at 60% life... I had not used the phone at all!
Media server is what serves up music from streaming such as Google Music, Pandora or XM. It also increases from using Google Currents.Media Server is what accesses files on your local storage, if you're playing a lot of locally stored songs/media the battery usage from that will show up as media server.
That sounds right. I notice it goes up a little when I use Google Music or XM but nowhere near as high as it did before the update.I haven't seen a problem with it since the 4.2.2 update.
If you still have issues, then I have to think there may be some sort of actual media file corruption.
Don't know how true this is. I never stream Google Music, but have had media server issues in the past. It keeps waking your phone due to a corrupted file or something. Even still, not sure how Currents relates to the media server. I mean, what if he doesn't even have it installed?
Also, I tend to disagree with any ideas that suggest turning off Google Now. One of the most essential and great features of Android, and you turn it off? Folks get great battery life without doing that so I think something else is an issue.
Every one has Currents installed by default since it came installed on the phone when you got it. As soon as I disabled it, battery life improved and Media Server stayed way down in usage.
I don't find Google now useful. All it ever did was show the weather for me and eat up battery. Why do I need it? I want my battery to last for calls and music. That's what I want a phone for. What's important to me is important to me, not you. Google now does use increase usage because it is constantly using location to find where you are.
Current isn't installed on custom ROMs.
The keyword in your second statement is "I". I wouldn't suggest disabling Now to anyone since only the minority feel as you feel. Majority get good life with Now. That's all I'm saying. We're talking about a media server issue anyway so I didn't understand the point of suggesting that. No offense in any of my comments by the way.
To the OP, there are a few threads about this. Typically a reboot will fix it. Others say delete all your music files. This is an issue I would like to see solved as well. Disabling Current and Now most likely won't do it for ya.
Go into settings/apps, disable currents or open currents and disable syncing in settings. Also, turn off Google now.
Google Music will still work just as it did before.To everyone suggesting I reboot... do you really not think that Ive tried that?
Ok, but what happens if I want to use Google Play Music to play music? Am I going to have to compromise being able to listen to music on my phone for battery life?
No. It will cause mediaserver to increase it's usage though while you are streaming music because that's what enables you to stream. Once you stop using Goole Music, mediaserver won't increase it's usage until next time.Right, but will using Google Music activate Mediaserver to go into its infinite loop battery drain?
If you have the music stored on your phone, mediaserver won't be used at all. Stopping currents app will stop mediaserver from using up the battery while you are not doing anything since it will not constantly keep updating those magazines and news with current stories.
Good stuff. So how do I disable Currents and Google Now?
