Results 1 to 5 of 5
- 03-15-2013, 07:41 AM
Thread Author #1
Crazy battery readings and behavior despite recalibration and multiple charge cycles
I need some help........
I charge my phone until it reads 100% and it shuts off around 60 to 70%. When i turn it on it shows 2-10% on restart and sometimes it doesnt even get past the boot screen before shutting off again. Now whats weird is after a few minutes if I plug in the charger, it will boot up and show 40%, and when charging its very quick and shoots to 100% in about an hour. Usual full charge time for me is a little over 3 hours....
i've reset the battery stats by using the app and even going into the system folder to delete the batterystats.bin file multiple times.
this all started when i was running slimbean rom and on franco kernel...so i did a full factory image flash to stock and wiped everything to start from scratch and it still does this so i dont think it was a rom issue. it also shows these weird stats in twrp recovery and other battery stat applications.
is there any fix for this? i think my phone thinks its charged at 100 percent when its not....i don't wanna drop another 300 bucks unless i really cant fix this....any help would be much appreciated.
thanks all - 03-15-2013, 10:06 AM #2
Re: Crazy battery readings and behavior despite recalibration and multiple charge cycles
go to recovery and clear battery stat from there
- 03-15-2013, 10:55 AM
Thread Author #3
- 03-15-2013, 10:56 AM #4
- 03-15-2013, 11:00 AM
Thread Author #5
Razr brick / dead battery / fully fixed with bread ties and tweezers.
By efbld2f in forum Droid RAZR HDReplies: 0Last Post: 09-18-2012, 01:01 PM -
Strange inconsitent wifi behavior with iphones and android
By Booshanky in forum General Help and How ToReplies: 4Last Post: 05-31-2012, 01:42 PM -
Bricked.. very important to 1) wifi, and 2)plugged in with fully charged battery
By pdsnas in forum AT&T ATRIXReplies: 4Last Post: 08-25-2011, 10:34 PM -
Awful Battery w/ BAMF 1.8.6 and How I Fixed It
By PapaSmurf6768 in forum Thunderbolt Rooting, ROMs, and HacksReplies: 1Last Post: 07-30-2011, 11:04 AM -
Good read on moto/google/android and problems that ensue
By Flawson in forum Motorola Droid XReplies: 4Last Post: 09-25-2010, 06:47 PM
Reply
