1. Muthu kumar3's Avatar
    Hi,
    I had a Nexus 4 and I was able to connect it to my laptop (windows 8) and was able to transfer files via USB - (MTP Connection).
    We just bought one for my friend and when I try to connect it to my laptop, it does not work. The phone seems to charge, but the MTP connection does not work. On the other hand, when I change the connection as "Camera(PTP)" it works.
    Can some one advice on why it does't work with an MTP connection? Thanks.
    03-19-2013 11:12 PM
  2. swebb's Avatar
    Not sure about Win8 but I know in WinXP that USB debugging needs to be off in developers options for it to connect as MTP. You can try to toggle this off/on to see of it makes a difference.
    03-20-2013 07:49 AM
  3. Muthu kumar3's Avatar
    I tried toggling the USB debugging. But it did't work. What surprises is that my nexus 4 works properly but the one that of my friend's nexus 4 causes this problem, though on the same laptop..
    03-20-2013 09:32 AM
  4. 5c077's Avatar
    I just ran into the exact same thing. My Nexus 4 works fine but wifes doesn't. Anyone have any ideas?
    04-04-2013 09:11 PM
  1. Tether Nexus 7 to iPhone 4 to use data connection - Problem connecting
    By Andy Bell in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-05-2013, 05:08 PM
  2. USB Connectivity Problem with Nexus 4!
    By Boris Abramov in forum Google Nexus 4
    Last Post: 02-02-2013, 07:38 PM
  3. Nexus 4 connectivity problems
    By hkdflip2 in forum Google Nexus 4
    Last Post: 01-19-2013, 08:19 PM
  4. Nexus 7 Connectivity Problem
    By jsinco in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-13-2012, 04:15 PM
  5. Nexus S WiFi connection problems
    By Zebedee#AC in forum T-Mobile Nexus S
    Last Post: 01-07-2011, 01:15 AM
