1. RavenSword's Avatar
    I'm completely clueless how to get my nexus 4 to connect to my ipad mini as a hot spot.
    I enable all the right stuff on my nexus 4, but the wifi only ipad mini never recognizes the device when searching for compatible blutooth devices. Is there something I'm missing?
    05-10-2013 01:31 PM
  2. joshtrader's Avatar
    why are you using bluetooth? use the wifi hotspot feature it worked for me well
    05-10-2013 03:55 PM
  3. jdbii's Avatar
    Sometimes you have to put a code for bluetooth devices to sync. 0000 or 1111 might work. I tether Internet from my N4 to my N7 over bluetooth no problem. It's possible that IOS and Android don't play nice.
    Citizen Coyote likes this.
    05-10-2013 05:30 PM
  4. xstinkyx's Avatar
    Yes, why would you use bluetooth to connect to your wifi "hotshot"?
    You want to go into the General -> Wi-FI settings in iOS and your N4's ssid should be listed there (if you have it on)
    05-10-2013 06:59 PM
  5. jdbii's Avatar
    i thought it used less battery power for both devices. the speeds are slower when you tether or share internet by bluetooth, but i kind of regarded that as a good thing because then you don't burn through as much of your wireless plan's data allotment. it is still fast enough to stream video.
    technically i don't think it is connecting to a wifi hotspot because you don't have to have wifi hotspot toggled on your N4, nor do you need to have wifi enabled on your N7, but rather sharing internet by bluetooth between devices.
    05-10-2013 07:17 PM
  6. wunderbar's Avatar
    just use wifi instead of bluetooth.
    05-10-2013 10:35 PM
  7. anon5664829's Avatar
    No, I use my Nexus 4 for wifi tethering to my iPad 4 so it works really well.
    Posted via Android Central App using my Nexus 4
    05-11-2013 12:14 AM
  8. Citizen Coyote's Avatar
    I suspect it's probably an issue using bluetooth between iOS and Android as well. OP, just set up the N4's hotspot and use your iPad's wifi and you'll be fine.
    05-11-2013 10:51 AM
  9. Advait Gangoli's Avatar
    My iPad mini connects with myGoogle Nexus 2 but it doesn't connect with the App Store. Its really irritating.
    07-13-2013 09:07 AM
  1. Can't get S voice to work with my Car's Bluetooth.
    By johnj2803 in forum Samsung Galaxy S3
    Last Post: 07-13-2012, 09:43 AM
  2. Trying to get WIFI tether to work with root Epic
    By alb53 in forum Epic 4G Rooting, ROMs, and Hacks
    Last Post: 07-16-2011, 01:59 PM
  3. Can't get some feeds to work with pulse
    By ToothVore in forum Android Apps
    Last Post: 11-16-2010, 01:07 PM
  4. Cannot get wifi tether to work!
    By jason821 in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 07-24-2010, 08:00 AM
  5. How to get wifi tether to work
    By alex5252 in forum HTC Droid Eris Rooting, ROMs, and Hacking
    Last Post: 04-18-2010, 07:54 PM
