Results 1 to 7 of 7
    reneeh63's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Problem with display and rebooting
    After charging overnight, my Nexus 4's display won't display properly - when I single press to turn on it shows up as a very dark shade of gray, barely detectable that it is even on. If I long press to reboot, I can see the "X" come up but very dimly...it then goes to my lockscreen and then my homescreen but everthing is extremely dim. I can barely see, but when I try to manually set the brightness, it has no effect. Then it goes into sleep mode and I have to reboot again to get anything to show up. I've never had this issue before in the 5 months since purchase.
    I've been messing with it all morning and a couple times when I rebooted the screen displayed in proper brightness but as soon I stop using it goes back to sleep and I have to reboot. I tried changing the daydream to off and to change the sleep time but no real change.
    Any ideas? - I'm not rooted.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,091 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Problem with display and rebooting
    Quote Originally Posted by reneeh63 View Post
    Not sure how on a Nexus 4, but if you tried clearing the cache in recovery. That might help.
    reneeh63's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Golfdriver - don't I have to be rooted to do that?
  4. #4
    mcelmeel17's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try a factory reset before you do anything crazy. They can work wonders
  5. #5
    Posts
    Global Posts
    33,091 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Shouldn't need to be. Try powering off, the to reboot into recovery try power and volume up till you see the opening logo. Should come to a menu..use vokume to navigate highlighted bar and select wipe cache partition.
    reneeh63's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well, I tried clearing the cache and then finally convinced myself to do a factory reset...and it didn't change a thing - including rebooting to a grayed out screen and everything else. Is there any option other than returning it? It's not like I just got it, it's been three months so I'm kinda attached...!
  7. #7
    Posts
    Global Posts
    33,091 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Sorry about delayed response. Try contacting Google. This sounds like a software/ROM issue.
    Sent from my GT-P3113 using Android Central Forums
  1. problems with camera and battery
    By piper09 in forum HTC Hero
    Last Post: 06-26-2013, 11:02 AM
  2. Problem with launcherpro and animated weather
    By stolzyboy in forum Android Apps
    Last Post: 11-19-2010, 01:03 PM
  3. Problem with 3G and beautiful widgets
    By chetman7 in forum Verizon Droid Incredible
    Last Post: 09-26-2010, 01:26 PM
  4. Problem with Market and paid apps after 2.2 upgrade
    By MarqBland in forum HTC EVO 4G
    Last Post: 08-10-2010, 09:29 AM
  5. problem with apps and display?...help
    By Kamran1981 in forum Motorola Droid
    Last Post: 01-17-2010, 06:17 PM
