1. mattatwar1's Avatar
    my nexus 4 charger (stock charger) is emitting high pitch noise... and is this guy correct? --> "Basically, instead of using mains frequency AC conversion in a transformer (50Hz, big transformer), the system uses high frequency (15kHz+) transformers, which can be much much smaller. A vibrating transformer is all you can hear. Not all chargers do it, you're just unlucky."
    05-25-2013 12:41 PM
  2. Jnorton2724's Avatar
    My Nexus 4 charger had the same problem and just didn't charge anymore. Seems like some people just got a crappy charger with the phone. You can get another one from the store or check T-Mobile to see if they sell the same charger since they sell the phone.
    Sent from my Nexus 4 via Android Central App
    05-25-2013 12:57 PM
  3. mamutarka's Avatar
    my N4 charger also has some annoying buzz sound..
    05-26-2013 11:23 AM
  4. donm527#IM's Avatar
    yeah the factory charger is cheap and if it works will eventually charge at a snails pace and make a sound coming from the charger. this is with two chargers i got from google. get an andru charger and be done with it.
    Andru - Android Robot USB Cell Phone Charger
    05-26-2013 01:53 PM
  5. Captainbob767's Avatar
    You are correct, the power supply in these little wall wart type supplies is running at a high frequency, and there generally is a transformer in the supply, and that is what is vibrating at the high frequency. Depending on your hearing, and how loose the lamination in the transformer are, you may or may not hear it. It could be annoying, but it causes no reliability problem.
    05-26-2013 02:01 PM
  6. mamutarka's Avatar
    there isn't EU version of adapter
    05-26-2013 02:37 PM
  7. Goodeye's Avatar
    I get the same noise. However it goes away when I plug the phone into the charge cable.
    05-26-2013 05:41 PM
  1. Samsung Galaxy S4 screen turns to green and make a high pitched screeching noise
    By Thien Trinh in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 05-22-2013, 09:10 AM
  2. Asus TF300 32GB high pitch sound during video recording
    By CRS1 in forum ASUS Transformer Pad Infinity 300
    Last Post: 03-10-2013, 11:51 AM
  3. high pitch sound coming from samsung phone charger..
    By StatuSChecKa in forum Samsung Galaxy S II Skyrocket
    Last Post: 11-08-2011, 10:36 PM
  4. High pitched squealing when I try to make a call
    By Chondog in forum Verizon Droid Incredible
    Last Post: 05-20-2010, 11:12 AM
  5. high pitch sound
    By scotth45 in forum Verizon Droid Incredible
    Last Post: 05-14-2010, 07:08 PM
