I just bought a used nexus 4 that the person had rooted. I want to go back to out of the box stock 4.3. This is my first nexus and am a little unsure how to do this. I'm running a macbook pro as my computer if that helps at all
Actually if it's not on a custom ROM, just doing a factory reset from the settings ought to unroot it I'm pretty sure
Okay so first are you just rooted or is there a custom rom installed? If the phone is just rooted then my advice would be to leave it as it is as having root access does not affect the performance or feel of the phone at all. If you do still want to unroot then you have to decide if you want to just unroot or if you want to unroot and relock the bootloader. To unroot you will have to flash the factory images. You will lose all the data on your phone but there is a way to leave you userdata unchanged. You will also need to decide whether you want to do things manually which will give you better knowledge or using a toolkit which is easier.
Here is what the person sent me when I bought it
I left the Bootloader unlocked and flashed a stock Odexed ROM on it, but its still rooted. I hope this is OK. I didnt know if you used custom ROMs or not and you said to return it to stock, but I wasnt sure if you wanted Root removed as well.** It has TWRP recovery.
Not sure what it actually means haha
Odexed means the cache for apks is contained separately in a .odex file while deodexed is when the cache is kept within the apk itself in a .dex file. Odexed has faster booting times but deodexed allows for more customisation which is why custom ROMs are usually deodexed. Im sure stock is odexed as it is more safe and what the guy meant is that he put stock rom back on the phone. Go to about phone in settings and see what it says about your build version, kernel version etc. The device is rooted with an unlocked bootloader and a custom recovery. Like I said before, having root wont really affect anything except gaining access to system files but it is up to you whether you want complete stock.
This is what I see in system settings. I'd prefer going back to complete stock for now.
http://img.tapatalk.com/d/13/07/28/peqequgy.jpg
I'm going to ask the question I thought the OP was asking because I'm pretty much a total noob when it comes to this stuff but I want to learn Anyway. I just purchased a Nexus 4 on eBay and it's running CM 10.1. I'd like to go back to square one, 100% 4.3 stock, locked bootloader, etc. if that's possible. If it's not, then flashing to 4.3 ought to do. I really only have a desire to be rooted on an otherwise stock device. But if I do delve into flashing roms I want to learn from the ground up with a stock device. Here's MY settings if it helps:
I'd like to do it manually first.
Thanks so much! I'll let you know how it goes.
I dont know why I didnt just link you to 2def's guide Having a bad day :-[
