1. Andy Bell's Avatar
    Hi,
    Since receiving the 4.3 update and moving to an area where the signal isn't as good I appear to be having antenna issues.
    Basically the new house I'm in isn't the best for signal, there are a few places I can get reception but it's not the best. I have noticed that the way I hold my phone can drastically affect the signal, if I grasp the phone round the bottom with my hand cupped round the back I see the signal drop almost immediately, then if I change and hold it with my middle finger at the top and thumb at the bottom so I'm not really covering the back the signal returns.
    This only seems to have been happening since the 4.3 update, I initially thought it was down to the poor signal in my house but I have noticed it at work where the reception is good.
    just wondering if anyone else had noticed the same problem?
    08-23-2013 03:49 AM
  2. Greg C's Avatar
    I've had no reception issues since the update. I've heard of some people having a weaker wifi, but not weaker cell reception.
    08-23-2013 04:24 AM
  3. akkicasanova's Avatar
    I have had the same problem. Since the upgrade to 4.3 my signal automatically goes off. This issue has come up only since upgrade to 4.3. Please tell me if you found a solution.
    08-23-2013 10:14 PM
  4. Jeremy_Collinsworth's Avatar
    I have a solution, but you need to be rooted/have a custom recovery. Just flash down the modem to the one for 4.2.2. There, issue resolved (95% positive). For you guys that aren't rooted, you're stuck waiting for an update.
    Sent from my SAMSUNG-SGH-I747 using AC Forums mobile app
    08-23-2013 10:19 PM
  5. jdbii's Avatar
    If holding your phone a certain way impacts cellular reception does that mean that phone cases can negatively impact your phone's reception as well?
    08-23-2013 10:39 PM
  6. Jeremy_Collinsworth's Avatar
    Yes, a case can have a negative impact at the moment.
    jdbii likes this.
    08-23-2013 10:42 PM
  7. N4Newbie's Avatar
    Install an app like Network Signal Info ( https://play.google.com/store/apps/d...android.telnet ), fire it up, and monitor your cell and WiFi signal strength as you shift your hand around and add/remove your case.
    No matter how hard I try, I cannot see more than a 1 to 2 db difference.
    I have a first-generation N4 (hardware level Rev. 10) running stock 4.3 OS.
    08-24-2013 06:33 AM
  8. Andy Bell's Avatar
    I'll give the Network Signal App a go and wee what the results are.
    Thanks for the replies thus far.
    08-27-2013 02:53 AM
  9. Andy Bell's Avatar
    OK,
    So I installed the app and the results are:
    Holding the phone with the thumb at the bottom and ring finger at the top (get the best signal this way)
    -113dBm
    -109dBm
    -107dBm
    Clasping the phone with my hand cupped round the bottom/back
    -95 dBm
    -93 dBm
    I don't really know how much difference this makes really but the way you hold the phone definitely affects the signal.
    08-27-2013 03:04 AM
  10. Andy Bell's Avatar
    08-27-2013 03:11 AM
  11. N4Newbie's Avatar
    Actually, -93dB is s significantly STRONGER signal then -113dB.
    Decibel - Wikipedia, the free encyclopedia
    08-27-2013 05:26 AM
  12. Andy Bell's Avatar
    You're right, I get my results the wrong way round!! Thanks for pointing that out.
    Andy.
    08-27-2013 05:49 AM
  13. Rule9's Avatar
    I've been around those numbers indoors since launch. Fwiw the radio is located at the bottom left which is why it drops when you palm it. I don't get drops or any of those issues some people were reporting after 4.3 prior to the recent patch to fix it though
    08-27-2013 04:52 PM
  14. Andy Bell's Avatar
    So has there been a further update to 4.3 to fix the radio issue?
    08-28-2013 05:57 AM
  15. Rule9's Avatar
    My mistake, the patch is being worked on now but not out yet
    08-28-2013 12:37 PM
  16. Andy Bell's Avatar
    I did actually receive an update for 4.3 last night............not fixed the issue though.
    08-29-2013 01:40 AM
  17. itic's Avatar
    Have tried a signal booster app?
    08-29-2013 10:31 AM
  18. Andy Bell's Avatar
    Do they really work? If they do can you recommend one?
    08-30-2013 02:59 AM
  19. itic's Avatar
    Network Booster. its free and seems to help.
    08-30-2013 10:06 AM
  20. Orane Cole's Avatar
    I just received the 4.4. update and still experiencing the signal loss issue.
    This issue has been there since i got the 4.3 update as is the case with everybody else.
    I would really appreciate a fix for this as the work around i have employed is really annoying and makes the use of my Nexus 4 device counter intuitive.
    I really was looking forward to this 4.4. update just to be faced with the same bug.
    Someone please help.
    11-26-2013 06:09 PM
  21. tbrady8's Avatar
    I have the latest Nexus 4 and I've had the same issue with the radio signal since day one. Even with 4.4.2 it's still the same. I just figured it was the area I live.. the T mobile coverage map shows my address being in a pretty good area but once I'm a couple miles from home the signal drops drastically. One inside forget it.. I'm constantly holding the phone on its side or upside down to get 1 bar. In town & where I work it's fine. I guess my complaint would be the antenna being on the bottom. Doesn't make sense to me at all. This is the only Nexus 4 downfall for me. A good WiFi calling app is a must.
    01-26-2014 02:29 AM
  1. Nexus 4 stuck at Google Logo
    By Dylan Tittel in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 01-05-2014, 05:26 AM
  2. Mobile hotspot issues and temp workaround
    By dariusf in forum T-Mobile Galaxy S II
    Last Post: 08-27-2013, 11:47 PM
  3. I spilled milk on my Nexus 7 and need help.
    By kal1209 in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-25-2013, 06:33 PM
  4. nexus 7
    By Nick Black in forum Google Nexus 7 Tablet (2012)
    Last Post: 08-22-2013, 11:17 PM
  5. No MIFARE NFC Support on Nexus 7 2013?
    By Ranfu in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-22-2013, 08:59 PM
