Hi folks. I've somehow managed to disable my mobile data connection after messing around in my settings yesterday trying to save some battery life. Everything was fine up until then.
I have 'data enabled' ticked (settings > more > mobile networks > data enabled) and "mobile data" is switched on (settings > data usage > mobile data) but I cannot get mobile data to work. When I attempt to load a webpage (for example) I see some arrows (upstream/downstream?) on my mobile network strength indicator (which varies between 3G and H) but the strength icon stays grey rather than going blue and I get nothing.
It seems I can get some kind of data through as I can use Google Now and Google+ but only in a very limited capacity. But when I try to use Chrome (for example) I am out of luck; it tells me I am offline or that it can't connect to the page. I can't work out where else in Settings I can go to rectify this. It's not a carrier issue as I have done a side-by-side comparison with another person who uses the same carrier and they have no problems. I am not over my billing allowance for the month either.
I am guessing it's something to do with an app I disabled in my quest for greater battery life. But I've been through the Apps list (settings > apps > all) repeatedly and can't see what I can do (or un-do). Arrgh.
Does anyone have an idea for what I could do to try to fix this problem?
Thanks in advance.
Silver lining: At least now I've discovered this site!
