Results 1 to 13 of 13
    Default Android 4.4 screen rotation problem.
    Hi, So I just updated to Kit Kat, and when I set my own custom background and then press the multitasking button (when the phone is in landscape), the wallpaper is cropped and there is a big box of black on the right.
    Sorry about the vagueness of the description, I find it really hard to describe, so here is a picture to show you guys what it looks like...
    From android 4.3 and even 4.2.2, the wallpaper auto-adjusts so that it fills up the screen when it is in landscape...
    Does anyone have this problem too?
    What should I do to solve this?
    Anyway, thanks in advance!
    *This is my first thread, so I apologize if this is really poorly written.
  2. #2
    Default Re: Android 4.4 screen rotation problem.
    I had a similar problem and a reboot fixed it
    Posted from my "CrackDroid" Nexus 4 via the Android Central App
  3. #3
    Same on Nexus 7 2013 with KitKat.
    I usually use it in portrait so it's easy for me to ignore.
  4. #4
    Quote Originally Posted by Jason95014 View Post
    Just follow this link com.google.android.launcher-0.9.6.886092.apk | by Android Police for Generic Device and install this launcher file on your pc or from mobile browser direct to your mobile , then install easy installer from play store and go to securtiy and check mark on unknown sources column , ignore warning and click ok. If you have downloaded the launcher file in your pc then connect your phone to pc and copy and paste this file to your mobile . Open easy installer and it shows the launcher file , install it through easy installer and after installation click the done button. Now press home button and select the new launcher and WOW just experience the NEXUS 5 on your nexus 4.
  5. #5
    Quote Originally Posted by sameer kapoor View Post
    That has nothing to do with the question of the OP..
    Sent from my Nexus 4 using AC Forums mobile app
    Quote Originally Posted by sibeans View Post
    What exactly entails a reboot? does that mean factory reset?
    Also, just FYI, I downloaded the GEL launcher from android police because I thought the 4.4 update was a disappointment. Google left out some features for the nexus 4, which makes me really sad...
    Regardless, the rotation problem described above also occurs for the stock launcher, too.
  7. #7
    A reboot is when you turn off your phone, and then turn it back on.
  8. #8
    Dear watetdroid , there is no screen rotation problem in GE Launcher , I have explained everything clearly and I understand it well enough .
    I actually installed the GE launcher...
    Sameer, there is a problem with the screen rotation for stock AND GE Launcher.
    - - - Updated - - -
  10. #10
    - - - Updated - - -
    Hi Jason , I have found a solution - install a free app from playstore named PicSpeed Wallpapers 500,000 - after installing it - open gallery - select desired picture for wallpaper- click menu from upper right corner - click set picture as - click option set as wallpaper ( with picspeed app logo) - click set and your wallpaper is set . I found if I set my wallpaper with this method then it adjusts itself in landscape mode . Just give a try, Good luck. Take care. By the way this app is also great for new HD wallpapers.
  11. #11
    That did not work for me on a nexus 7 2013
  12. #12
    Quote Originally Posted by David Sontag View Post
    Sorry, but I haven't tried it on nexus 7. I am using nexus4.
  13. #13
    It seems to be a problem the the OS itself. I've had other media, including videos do the same thing when I rotate my Nexus 7.
  1. Samsung Galaxy S4 Active - app shows on locked screen
    By dzseti in forum Samsung Galaxy S4 Active
    Last Post: 02-08-2014, 10:15 PM
  2. Kogan android doesn't recognise my SIM card as 'local'
    By edfdave in forum General Help and How To
    Last Post: 12-16-2013, 03:21 AM
  3. Samsung Galaxy Tab 2 10.1 - Android 4.2 menu button?
    By Erratically in forum Samsung Galaxy Tab 2 10.1
    Last Post: 11-24-2013, 10:30 AM
  4. Replies: 3
    Last Post: 11-23-2013, 04:35 PM
  5. Home screen problem
    By fishbowl38 in forum Android 4.4 KitKat
    Last Post: 11-23-2013, 06:43 AM
