Results 1 to 5 of 5
    Default Android 4.4.1 also fixes camera problems on the Nexus 4?
    does it only fix the camera issues on the Nexus 5 or does it work for the Nexus 4 also?
  2. #2
    Default Re: Android 4.4.1 also fixes camera problems on the Nexus 4?
    Pretty sire the camera fix is for the 5 but there would be other tweaks for the nexus 4
    - Android Central App. Remember courage is contagious.
    Tom Fairclough
    Credo faber est quisque fortunae suae
    I believe every man is the artisan of his own fortune
    Quote Originally Posted by Fairclough View Post
    f*ck...they said they were going to fix the nexus 4 camera when it came out and now 1 year later and still nothing....damn google
  4. #4
    Not sure if I'm halucinating or some of my posts gets deleted, not aware of breaking any forum rules.
    Anyway. Looking at the OTA package the camera app is updated along with many other apps. Whether that means anything to camera improvement, you'll just have to try it out for yourself.
  5. #5
    Quote Originally Posted by jinjin12 View Post
    Don't think they ever announced a camera fix. Reviewers just said that the camera could be fixable with an update, but Google never acknowledged a problem or mentioned a future update fixing the problem, as was the case with the N5. BUT, hopefully that new camera API they're supposedly working on does the trick.
    Sent from my Nexus 4 using Tapatalk
  1. Replies: 10
    Last Post: 02-21-2014, 12:34 PM
  2. LG G Pad 8.3 and the Optimum app
    By matty3054 in forum LG G Pad 8.3
    Last Post: 12-12-2013, 01:24 PM
  3. Google Nexus 10 and the Optimum app
    By matty3054 in forum Google Nexus 10 Tablet
    Last Post: 12-12-2013, 10:43 AM
  4. Replies: 12
    Last Post: 12-09-2013, 03:35 PM
B
