1. mastrK13's Avatar
    When I try to send an MMS I get a text from "500" that says "Your MMS message could not be delivered due to insufficient funds or MMS blocking." problem just started out of the blue. Never had any problems beforehand and didn't change anything I'm aware of.
    12-06-2013 09:09 PM
  2. sibeans's Avatar
    I had the same situation on a tmo postpaid plan, you have to dive into settings to set an APN (or something). You'll find the fix from a quick search on tmo support.
    Posted from my "CrackDroid" Nexus 4 via the Android Central App
    mastrK13 likes this.
    12-06-2013 10:17 PM
  3. someguy01234's Avatar
    Fix your APN.
    <apn carrier="T-Mobile US" mcc="310" mnc="260" apn="epc.tmobile.com" user="none" password="none" server="*" mmsc="http://mms.msg.eng.t-mobile.com/mms/wapenc" type="default,supl,mms" />
    <apn carrier="T-Mobile US LTE" mcc="310" mnc="260" apn="fast.t-mobile.com" user="none" password="none" server="*" mmsc="http://mms.msg.eng.t-mobile.com/mms/wapenc" type="default,supl,mms" />
    <apn carrier="T-Mobile US LTE IPv6" mcc="310" mnc="260" apn="fast.t-mobile.com" user="none" password="none" server="*" mmsc="http://mms.msg.eng.t-mobile.com/mms/wapenc" type="default,supl,mms" protocol="IPV6" />
    12-06-2013 10:42 PM
  1. S3 Mini restart/switching off by itself problem
    By F_E in forum Samsung Galaxy S3 Mini
    Last Post: 11-01-2016, 06:38 PM
  2. Should Android Central have blackberry section?
    By bitek in forum General News & Discussion
    Last Post: 06-30-2014, 07:36 AM
  3. HTC One apn settings problem
    By zrxoa1 in forum HTC One M7
    Last Post: 12-08-2013, 07:25 AM
  4. Can the Verizon LG G2 be used on T-Mobile network?
    By tvo1692 in forum Verizon LG G2
    Last Post: 12-06-2013, 10:39 PM
  5. Need help or OTA pacakge zip for 4.2.2 update - DNA on t-mobile
    By poots1101 in forum Verizon Droid DNA
    Last Post: 12-06-2013, 08:47 PM
