1. jenzzz's Avatar
    I've had a Nexus 4 phone for about half a year now, and from the beginning, there's always been an overheating issue - not just a little warm to the touch, but uncomfortably-burning-in-my-pocket type of thing. It usually only happens when I leave it in enclosed spaces, such as a pocket or backpack, but there's no way I can keep my phone in my hand all the time! It keeps heating up, and the battery will go from 95%+ down to being dead within 2 hours. Has anyone else had the same experience and/or knows of any possible issues? Thanks!
    01-07-2014 08:18 PM
  2. CoMoNexus's Avatar
    I've had an N4 for almost a year, and this happens every few months. I've never figured out the cause, but restarting always fixes it.
    01-08-2014 08:09 AM
  3. okiecardinal's Avatar
    Check your GPS settings. When it is running constantly the N4 gets hot.
    01-09-2014 03:30 PM
  4. Vinod kg's Avatar
    I am also getting the same problem of over heating. Battery shows full, but in drainage out in less than 2 hours. Unpredictable performance worried me a lot. Any solution??
    08-09-2014 03:23 AM
  5. lmvine's Avatar
    Depends on what is draining battery. Clearing the cached data under storage & downloading/implementing Gservicefix app did the trick... at least for now.
    08-09-2014 08:55 AM
  1. Replies: 12
    Last Post: 01-12-2014, 11:14 PM
  2. Android OS battery drain
    By slyder0244 in forum Sprint Galaxy S III
    Last Post: 01-09-2014, 09:14 AM
  3. best buy offering nexus 7 $25 google play credit (troubles)
    By gfsockmonkey in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-08-2014, 08:34 PM
  4. GT3 7.o questions and concerns
    By ilambson in forum Samsung Galaxy Tab 3
    Last Post: 01-08-2014, 01:32 AM
  5. Replies: 1
    Last Post: 01-07-2014, 07:35 PM
