Results 1 to 6 of 6
    Default Problems with my battery
    Hi all,
    I am having some issues with my Nexus 4 battery. Usually when it hits around 50% it suddenly drops to around 8%. Check out the screenshot:Click image for larger version.
    I have no idea what is happening. I have reset the phone around 3 times, which did not help. I also tried letting it die totally and then recharging it to 100%. Any idea what to do to fix this?
  2. #2
    Kelly Burby's Avatar
    Banned
    Posts
    Global Posts
    706 Global Posts
    Default Re: Problems with my battery
    Quote Originally Posted by dsl4life View Post
    Hi all,
    It looks like that there has been a problem with your battery, I think you need to replace your battery !!
    Quote Originally Posted by Kelly Burby View Post
    Don't think it can be replaced?
  4. #4
    How To Replace The Nexus 4 Battery (It Can Be Done) [Android]
    Proceed with caution! Have someone help you if you can
  5. #5
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    It can, but you need to open up the phone
  6. #6
    Also if you have a warranty they will replace the battery but make sure the phone isnt rooted or the bootloader is unlocked. You can use the Nexus 4 Toolkit to restore the phone if you have done anything fancy to the phone.
    Just for note if you do want to replace the battery, be very careful when taking the screws out and you use the right ones
  1. Is it just my Nexus 7 or is the touch sensitivity a little off on this thing?
    By JConn_Lefty in forum Google Nexus 7 Tablet (2013)
    Last Post: 04-07-2015, 01:47 PM
  2. LG G2: Can't connect to my home wifi all of a sudden
    By crazychris4124 in forum Verizon LG G2
    Last Post: 02-03-2014, 02:40 PM
  3. Replies: 4
    Last Post: 01-22-2014, 03:15 PM
  4. Avi problem
    By Livorno99 in forum Samsung Galaxy S4 Mini
    Last Post: 01-22-2014, 08:19 AM
  5. I think I may have found a problem on my Nexus 7 2013 :(
    By Sassi666 in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-22-2014, 01:03 AM
