1. Michael Jarmey's Avatar
    Hello, I have a Nexus 4 that had CM11 and was rooted but I was deleting things in rootbrowser and deleted the wrong file and the whole phone just crashed and now wont start up, I tried flashing a new rom and tried going back to stock but it wont show up on my computer, fastboot, or adb anymore and IDK what to do and I need help...it just stays on the boot screen and doesnt do anything else the file i deleted was in the framework folder and was an apk and im not sure how to fix it, it wont show up anywhere no matter where i plug it in at and its a very expensive paperweight now please help meeeee. I can still get to bootloader and into CWM but i cant flash or start up the phone at all.
    02-14-2014 12:03 AM
  2. JohnBB101's Avatar
    At the boot loader screen (before you choose to enter Recovery) the device is in adb mode, use a toolkit to push adb commands. Or use a toolkit to push a ROM zip onto your phone, enter Recovery, do a factory reset and flash the ROM.
    02-14-2014 12:48 AM
  3. Michael Jarmey's Avatar
    is there a good toolkit you can tell me about that can push a ROM on the phone??
    02-15-2014 11:23 PM
  4. JohnBB101's Avatar
    I use Wugfresh's Nexus Root Toolkit
    http://www.wugfresh.com/nrt/
    02-15-2014 11:43 PM
  5. JohnBB101's Avatar
    You'll find push/pull under Advanced Utilities
    02-15-2014 11:44 PM
  6. Michael Jarmey's Avatar
    Thank you ill try that and see if it works, ill let you know
    02-16-2014 09:11 AM
  7. Michael Jarmey's Avatar
    it didnt work, it didnt detect my device and I was in the bootloader...
    02-16-2014 01:58 PM
  8. JohnBB101's Avatar
    Enter recovery and try
    02-17-2014 03:35 AM
  9. Michael Jarmey's Avatar
    it still didnt work??
    02-17-2014 09:21 PM
  1. Nexus 7 Cast Screen Detecting Chromecasts
    By AndroidCentralSean in forum Google Chromecast
    Last Post: 06-05-2014, 06:31 PM
  2. Nexus 7 Battery Usage??!
    By cr250_250 in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-14-2014, 11:23 AM
  3. Help with N5
    By Vlosaloty in forum Google Nexus 5
    Last Post: 02-13-2014, 11:59 PM
  4. Phone Signal Problem & Battery Drain
    By galacticstormtrooper in forum Samsung Galaxy S4
    Last Post: 02-13-2014, 08:25 PM
  5. activation help-- rooted
    By ravencamp6 in forum Verizon LG G2
    Last Post: 02-13-2014, 07:43 PM
