1. Will_Oliver's Avatar
    Good night, since a week ago and I've been having issues with my n4(first badge of n4). It only shows USB charging even when I'm using the wall charger, it takes more than 12hrs to reach 100% charge, and it drains in less than two Hours. I have kit Kat and haven't done any changes, just using Themer.
    Any help please?
    Thanks Will.
    (while I wrote this, it went from 32% to 8% in 3 minutes)
    04-02-2014 01:24 AM
  2. srkmagnus's Avatar
    Seems like a bad battery. Consider a replacement battery if you are open to pulling apart the phone.
    04-04-2014 12:10 AM
  3. yodiyo's Avatar
    I've been having the same issue recently. I use various chargers and it appears to charge slowly on all of them suddenly.
    I also installed themer, so that might be an issue.
    Do the batteries degrade?
    05-09-2014 06:40 AM
  4. acejavelin's Avatar
    Yes, of course they do... Lithium Polymer batteries have a limited number of charge cycles and do gradually degrade over time.
    Look at your battery usage, preferably with BetterBatteryStats or GSAM battery monitor, and see if something is really draining the battery hard... if not, try a factory default, and if the problems continue it's probably time for a new battery, it's pretty easy to do.
    05-09-2014 08:27 AM
  5. Richard Lower1's Avatar
    Having same problems with mine so I have fitted a brand new LG battery and still the problem persists.
    12-17-2014 02:50 PM
  6. KRISHNAMOORTHY GOPALASWAMY's Avatar
    I have the same problem of heating and draining of the battery. I replaced the battery through the authorized service Centre. Still the battery drains about 60% overnight even when not put to use, with WiFi watched off. Anybremedy please.
    05-29-2015 09:30 AM
  7. AmbientApps's Avatar
    I have very similar problem with my battery. I think it's about battery drain / old. So I recommend your change with new battery.
    05-31-2015 08:06 AM
  8. belodion's Avatar
    Also, what do the battery usage stats show as the users of charge overnight?
    05-31-2015 08:34 AM
  1. [Info][Review] ROM comparison for the Nexus 5
    By Golfdriver97 in forum Nexus 5 Rooting, ROMs, & Hacks
    Last Post: 04-19-2014, 03:51 PM
  2. Samsung Galaxy S4 Battery Issue
    By rond997 in forum T-Mobile Samsung Galaxy S4
    Last Post: 04-05-2014, 06:31 PM
  3. Charging Cable for the Note 3
    By sonic1519 in forum Samsung Galaxy Note 3
    Last Post: 04-03-2014, 08:23 AM
  4. Question for those of you using GSam Battery Monitor
    By justlaxin13 in forum HTC One M8
    Last Post: 04-02-2014, 09:53 AM
  5. Replies: 4
    Last Post: 04-02-2014, 08:08 AM
