Greenify and JuiceDefender are decent, if configured correctly... Stay away from Snapdragon Battery Guru though.
The key to these apps is configuration, and "sleeping" or restricting the right apps and services, you can actually make you battery life if you do it incorrectly.
In general use I found most of these add little in normal, I skip them in most cases.
