Results 1 to 5 of 5
    grakhra's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Nexus 4 LED light
    Hi, should the LED be solid or flashing while charging?????
  2. #2
    zorak950's Avatar
    Posts
    Global Posts
    1,247 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Nexus 4 LED light
    Neither.
    grakhra's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks, this phone was on wet ground for more than 4 months. Picked it up dried it for a couple of weeks, recharged and voila!!!!! It powered up but water was was noticeable on the LCD screen. Every week or so powered it up to check the display, it turned ON okay. Even with the battery disconnected, with wall charger connected, the LED is solid. Last time when I turned it off it never turned on again. Any ideas what could be causing this?
  4. #4
    zorak950's Avatar
    Posts
    Global Posts
    1,247 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I can speculate, but anything I'd say would be a guess. Getting a phone that isn't built to be water resistant wet is never good, but if it seems to be working alright I wouldn't be too concerned. The LED should remain off unless it's activated by a notification, so the optimistic view is that something finally dried off. Or perhaps it just burned out, who knows.
    Did you lose it in the snow or something? :P
    grakhra's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, it was. It survived the -30 temperature. I did not expect to turn it on at all.
    Thx for the reply.
  1. Screen Casting was live on my Nexus 7
    By TKDnerd05 in forum Google Chromecast
    Last Post: 05-24-2014, 04:48 PM
  2. Replies: 9
    Last Post: 05-23-2014, 02:05 PM
  3. Replies: 0
    Last Post: 05-22-2014, 09:36 PM
  4. Anyone having Light Flow problems today?
    By dad2noah in forum Samsung Galaxy S5
    Last Post: 05-22-2014, 07:09 PM
  5. Replies: 2
    Last Post: 05-22-2014, 06:24 PM
