Results 1 to 6 of 6
    StijnDPr's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery drain after 4.4.3 update
    Hi,
    I'm having a really bad battery drain ever since I updated to 4.4.3. When I check what is eating battery life, I find that email is taking 88%, whilst I'm not doing anything new or special.
    Is anyone else having a similar experience? What should I do to fix this?
    Thanks,
    Stijn
  2. #2
    BetiZerbait's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery drain after 4.4.3 update
    Try eliminating the account, reboot and set it up again. I remember having a similar issue once
    Sent from my Nexus 4 using Tapatalk
    StijnDPr's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for your help.
    I followed the general advice to delete cache, and this appears to be working. Battery depletion levels are back to what they used to be.
  4. #4
    John Burgess's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Been having similar battery drain issues for some time. Looking at Settings -> Battery showed Google+ to be a major culprit.
    I have a rooted nexus 4 running stock 4.4.4
    I used Titanium Backup to 'Freeze' Google+ to prevent it from running.
    I also run DS Battery Saver in a pretty aggressive mode.
    Hey presto, between 7:30 am and 5:30 pm the battery has dropped < 15%
    May work for you...
  5. #5
    acejavelin's Avatar
    Posts
    Global Posts
    1,746 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Use Gmail and Google+, even automatic backup of media to G+ photos, all the time on 4.4.4, never had any battery drain issues... In fact, I have the best battery life I have had since 4.2, did you find out exactly what was causing the issue or did you just "eliminate" it?
    Stock rooted 4.4.4 + Hellscore kernel
  6. #6
    CeruleanBlue58's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm seeing a lot more drain, too. On 4.4.4.
    OP: Could you elaborate on what you did to delete the cache?
    I don't see the means any longer in 4.4.4 to sign in/out of Google Account. Where is it gone?
  1. Does weaker - but not no/barely any - signal still affect battery life?
    By icouldntpossiblycomment in forum Samsung Galaxy S5
    Last Post: 09-09-2015, 03:18 PM
  2. Will samsung galaxy s4 mini get emoji after android kitkat update???
    By simeonsmm in forum General Help and How To
    Last Post: 06-21-2014, 02:21 AM
  3. battery manager
    By 3user in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 06-12-2014, 11:47 PM
  4. 4.4.3 update bug
    By unnatipalan in forum Android 4.4 KitKat
    Last Post: 06-11-2014, 08:10 AM
  5. Can't Use Whatsapp After Factory Reset.
    By Akhil Chandran1 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-11-2014, 04:48 AM
