1. CeruleanBlue58's Avatar
    My N4 is stock, non-rooted. I don't have a ton of apps installed. It was working fine before the 4.4.3 and .4.4.4 updates, and now it's draining pretty darn quick, even while sleep and idled.
    Google Play Services and Android System are listed at the top of most consuming apps. How do I fix this, someone?
    06-27-2014 07:49 AM
  2. VDub2174's Avatar
    This seems to happen a lot after an update hits. It's happened to me a few times and after a day or so it seemed to work itself out for me.
    06-27-2014 08:13 AM
  3. acejavelin's Avatar
    Reboot... if that fails change your Location Services to Device Only, this will most likely reduce you battery drain significantly. Without having more detailed information from an app like GSAM or BetterBatteryStats to see what is truly using the battery, this is about all I can recommend.
    06-27-2014 09:20 AM
  4. CeruleanBlue58's Avatar
    I've deleted this and that cache, then rebooting, and still massive battery drain with Google Play Services and Android System at the top of the battery consumption list. Anyone have another suggestion on things to try?
    07-01-2014 07:36 AM
  5. sibeans's Avatar
    I updated via factory image restore and haven't had problems; n4 is rooted w/ stock ROM and kernel.
    07-02-2014 04:14 PM
  6. gusar2000's Avatar
    On google play store turn off automatic updates. It reduced drain in my case. Also, my phone needs a reboot once in a while (let say in 2-4 weeks) to reduce drain, otherwise Android OS starts to suck it up.
    07-03-2014 01:10 PM
  7. blemsbouife's Avatar
    good,I updated via factory image restore and haven't had problems; n4 is rooted w/ stock ROM and kernel.thanks
    07-06-2014 07:16 AM
  8. srkmagnus's Avatar
    Op, if you haven't already done so, consider a factory reset. Be sure to backup your data and see if that clears up your problems.
    07-06-2014 09:38 AM
  1. Update Notification For LTE Model
    By physioprof in forum Google Nexus 7 Tablet (2013)
    Last Post: 07-03-2014, 12:33 AM
  2. update problem
    By Venkataraman AP in forum Google Nexus 4
    Last Post: 07-03-2014, 12:03 AM
  3. My android auto updates even with auto update unselected.
    Last Post: 06-27-2014, 03:36 AM
  4. Galaxy Note 8 Battery Life?
    By Wwallender in forum Ask a Question
    Last Post: 06-27-2014, 02:55 AM
