Once again I suddenly find a massive battery drain and when I check I find WiFi has somehow managed to turn itself on even though I have it configured so that WiFi should only be on when charging. Presumably this is what is draining the battery. It is happening even with battery saver turned on. I will try it with battery saver off in case this is causing it. Any suggestions gratefully received.
