11-05-2013 04:57 AM
30 12
tools
  1. thegeneral101's Avatar
    Two different battery packs for the Nexus 5? This would be nice if proven true but it still doesn't address the fact it will be a sealed battery.
    Two Different Battery Packs Possibly Heading for the Nexus 5 Leak Out | Androidheadlines.com
    I've been searching the internet far and wide, but I can't seem to figure out if the battery will be replaceable even though its "sealed". I mean what's stopping someone from swapping them by pulling that ribbon out. I have the galaxy nexus now, and the removable battery was one of my favorite features. Although, I do have the 32gb Nexus 5 shipping today. Since the back cover comes out, it seems like there will be a solution to swapping batteries. What am I missing?
    11-04-2013 12:22 PM
  2. Papaguan's Avatar
    If you're savvy enough to take apart your phone, you can certainly replace the battery. Whether or not you can buy a bigger battery that fits the chassis of the device and uses the same connectors to interface with the device is another matter, however.
    11-04-2013 12:34 PM
  3. thegeneral101's Avatar
    Yeah, I'm not even concerned with putting a bigger battery in...more about having an extra two or three in my backpack when traveling. Having extra batteries with my Gnex has saved me multiple times.
    I was just curious if anyone has tried to swap the battery to a fresh one yet.
    11-04-2013 12:44 PM
  4. thegeneral101's Avatar
    11-04-2013 04:52 PM
  5. clevin's Avatar
    I don't think its worth the effort, why not just carry some battery powerpack? Seems a better solution than attempting to open the case and swap it in the middle of nowhere (assume that's the environment you most likely need extra power).
    11-05-2013 04:57 AM
30 12
  1. Replies: 19
    Last Post: 12-14-2013, 12:43 PM
  2. Nexus coming to Verizon?
    By rayden8 in forum Google Nexus 5
    Last Post: 11-05-2013, 07:36 AM
  3. Wireless & Networks settings for better battery life
    By Mustachio in forum Motorola Droid 4
    Last Post: 09-12-2013, 11:17 PM
  4. Replies: 4
    Last Post: 09-12-2013, 07:11 PM
