1. diesteldorf's Avatar
    I'll be brief. I know it's unlikely that Verizon will get a Nexus 5 with true cell radios and CDMA compatibility. I get that and concede that point.
    I know the Nexus 7 LTE will work on Verizon with 4G and has the following LTE compatibility:
    Dual-band Wi-Fi (2.4GHz/5GHz) 802.11 a/b/g/n
    LTE: 700/850/1700/1800/1900/2100 MHz
    HSPA+: 850/900/1900/2100/AWS (1700/2100) MHz
    GSM: 850/900/1800/1900 MHz
    Does anyone know if the Nexus 5 GSM edition will support the same Verizon LTE bands? Did the FCC specify?
    Both devices will not support CDMA and will not make or receive true phone calls on Verizon. However, if both of them support full 4G, I have an interesting choice.
    Get the Nexus 7 LTE for a bigger screen and minimally cheaper price or get a Nexus 5 with a smaller screen, easier portability, true phone capabilities should I travel abroad or want to ever use TMobile/ATT in the US, minimal cost difference.
    10-28-2013 11:30 PM
  2. lilotimz's Avatar
    There is only one version for the NA Market and that is the LG D820 which supports the following:
    • GSM 850/1900
    • W-CDMA 1900/2100+1700/850 (band 2, 4, 5)
    • CDMA1X/EV-DO 850/1900/800 (band class 0, 1, 10)
    • LTE 2100+1700/850/700/1900/800 (band 4, 5, 17, 25, 26)
    • TD-LTE 2600 (band 41)
    So no, it will not work on Verizon at all. In addition there is absolutely no way Verizons letting you just camp on Band 4 as that's a capacity offloading spectrum. Band 13 is their bread and butter and the entire reason they can say they have the largest LTE network in the USA and the D820 specifically does not support it.
    10-28-2013 11:47 PM
  3. moosc's Avatar
    Should copy n paste this in all the nexus5will it work or how can I get it to work on VZW. Vzw folks need to realize there is no nexus 5phone for us.
    • GSM 850/1900
    Sent from Bad Azz VZW LG G2 Cyan Tapatalk
    Jocelyn84 and UJ95x like this.
    10-28-2013 11:55 PM
  4. diesteldorf's Avatar
    Thanks for all the information. I knew there were differnet bands of 700 and 750 and that Verizon had band c in 700 for LTE.
    I can understand why Google wouldn't want to advertise or provide any support since it won't be able to make phone calls or support CDMA no matter what. I guess I just assumed it would support the same bands as the Nexus 7 LTE....Oh well.
    It is amazing that Google won't even advertise that the Nexus 7 does actually work on Big Red.
    10-29-2013 10:48 AM
  5. jasoraso's Avatar
    Don't forget that the Nexus 4 wasn't certified by the FCC to work on ANY LTE bands, yet it did.
    I would be very suprised if the Nexus 5 didn't have the capability of the VZW LTE bands, even though it hasn't been certified to operate on the VZW bands. It looks to me like the VZW CDMA bands are already certified. I think that Google could re-submit the Nexus 5 to the FCC for certification of the VZW LTE bands, after a small driver update.
    I believe that Google WANTS their phone on VZW. There might still be issues to resolve, but I am optimistic that it can happen.
    10-29-2013 01:57 PM
  6. Jocelyn84's Avatar
    Where?
    10-29-2013 02:03 PM
  7. jasoraso's Avatar
    The first post listed the FCC approval for CDMA for 800, 850, and 1900.
    Wikipedia indicates that Verizon uses 850 and 1900
    http://en.m.wikipedia.org/wiki/Cellular_frequencies
    Anecdotally, I've never seen a CDMA phone that works on sprint that couldn't work on Verizon, except for the fact the vzw didn't have it in their meid database
    10-30-2013 01:28 PM
  8. htowngator's Avatar
    People have been over this point already.
    While it seems some CDMA coverage bands are possible, the likeliness that Verizon would authorize the calling/texting aspect over CDMA is seriously doubtful. This isn't VoLTE and Verizon doesn't even have that yet so the phone would basically be a data device only -- not provisioned for calling. That's even IF you somehow managed to get on LTE bands correctly.
    10-30-2013 01:52 PM
  9. rover#AC's Avatar
    I am really hoping for Nexus 5 to be true global LTE phone, like the iPhone 5s, with not only NA bands in it. My travels in Europe take me to T-Mobile territor there that uses LTE Band 3, whicht virtually all US LTE models lack, with the exception of the new iPhone. I don't understand why other makers can't accomplish the same thing as Apple. Having one model serving all, or most carriers probably saves on manufacturing over several different models for various regional markets.
    By the way, some of the posters list LTE bands by frequencies only, not by band numbers. Since the phones work on separate d/l and u/l frequencies, I wonder which of those are listed in the single frequency listings. Band 3, for instance uses 1805-1880 Mhz for d/l and 1710-1785 for u/l. I suspect when the 1800 MHz LTE band is listed, it is really the d/l link frequency of Band 3, but I am not sure.
    10-30-2013 02:12 PM
  10. htowngator's Avatar
    problem w/ Apple's implementation for CDMA networks here is that they can't keep LTE data and do a CDMA call. If you call while on VZW, the phone will have 3G data. My Moto X on vzw shows LTE throughout the whole call because it has both radios separate (more power used but how often do you call?).
    10-30-2013 03:21 PM
  11. 318sugarhill's Avatar
    I had been wondering this exact same thing. Thanks for the info. So, with a 4G sim, I can pop it out of my S4, and into a Nexus 7 and it will work on Verizon. Ok, so when you look on the myvzw account, what shows up as your phone? I used to switch back and forth from my HTC rezound and S4 (with a SIM adapter) and it would show on my VZW which phone I was using at the time. What would show up when using a Nexus 7 (or a N5 if for some reason it turned out to actually support band 13 LTE)
    10-30-2013 05:34 PM
  12. JonK's Avatar
    Well if you dont call often, how often do you need LTE data during a call? Sounds like a fair enough tradeoff.
    It sounds like Apple is sharing antennas between radios. Most SOC's in phones now have all kinds of radios built in. The trouble is you have to pack antennas into the phone for all the different frequencies.
    10-30-2013 06:07 PM
  13. rover#AC's Avatar
    Sorry, I forgot that this thread is aimed at Verizon customers. I am a a T-Mobile customer, so it's GSM for me.
    10-30-2013 06:37 PM
  14. tr-1's Avatar
    I don't know about his case but I absolutely need this feature. I'm often day trade stock (yes on my phone LOL, since I don't want to be flagged at work) and when I get a call, I don't want to be disconnected from my traders chat room and live quotes. It can literally cost me $1000s.
    IMO there's absolutely no excuse for iPhone
    10-30-2013 06:42 PM
  15. longshot94's Avatar
    Absolutely I have the sim from my Verizon Galaxy Camera in my Nexus 7 as we speak with all sorts of LTE goodness.
    You can take ANY (yes you read that correct ANY) Verizon LTE sim and put it in any other LTE device that supports band 13 and it works just fine on LTE Data. With that said there is a caveat in that Verizon won't activate a device that has not been certified on their network yet. So you activate a sim with Verizon in a tablet or galaxy camera and then pop it in your device.
    10-31-2013 09:05 PM
  16. 318sugarhill's Avatar
    I'm going to get a Nexus 7 at some point either before/for/or after the holidays. I need a 32gb. I've tossed around spending the extra $70 or whatever for the LTE version. But I'm hesitant because now I currently tether my phone (yes I'm rooted). So wifi only works just fine for me. Not sure I'm completely comfortable being without a phone while I'm using the tablet either. I know I can forward my vzw # to Google voice and get my calls on the Nexus, but what about text messages? I need to be able to receive my VZW texts.
    11-05-2013 02:23 PM
  17. OrionAntares's Avatar
    Does anyone know if VZW charges extra to use this app?
    https://play.google.com/store/apps/d...ssaging.vzmsgs
    11-05-2013 04:27 PM
  18. diesteldorf's Avatar
    Nope, Just whatever you normally pay for texting.
    11-05-2013 05:23 PM
  1. Replies: 3
    Last Post: 12-31-2013, 11:59 AM
  2. Verizon Galaxy s4 4.3 Downloading Now!!!
    By carraser891 in forum Samsung Galaxy S4
    Last Post: 11-02-2013, 11:23 PM
  3. Even the slightest chance of it coming to Verizon?
    By tourboy in forum Google Nexus 5
    Last Post: 10-31-2013, 04:28 PM
  4. Replies: 4
    Last Post: 10-29-2013, 10:03 AM
  5. Anyway to change the font color and size of the icons?
    By doctorttt in forum Samsung Galaxy Note 3
    Last Post: 10-28-2013, 10:43 PM
