Re: Nexus 5 Problems and Issues list.
I have problems with the People (Contacts) app, which is more of a Kit Kat thing, but annoying nonetheless. I have the app sync with my Exchange account and It has created a contact for every email address I have used on my computer at work, most of which are not in my contacts. I cannot find a way to only show only my actual contacts. I have around actual 200 contacts and it is showing 865 contacts. If someone has a fix, I would love to know.
Is the lock screen supposed to be able shortcut to apps? It looks like it should, but I cannot find any setting for it. You can move in four directions, but they all just unlock the screen.
Overall, I am underwhelmed with the phone and Kit Kat. The phone is fine and has some good points, it is just not as good as others out there, for my purposes. The price point is a huge plus, but there are a lot of things that other manufacturers offer with their software that are missing from stock android. There are apps to fill many of the gaps, but I feel like I am working too hard to get what LG, HTC, Samsung and others give you out of the box (and work better). I have a hard time convincing myself that I should use it instead of my GS4, G2 or Note III.
