jerrykur
Re: Nexus 5 Problems & Issues
Weak Wifi is going to drive down your battery life pretty quickly as the unit disconnects and attempts to reconnect. Consider getting a second access point or at least a Wifi repeater (which will cut your throughout in half.)
Or alternatively leave your phone on a wireless charging pad when not in use. Then your phone will always be topped off and ready to go.
Thanks for that tip, I am going to try it. Have had some thoughts that my home Wi-Fi could have something to do with an only when I'm asleep battery drain issue I've been dealing with. It's super fast 30mbps Comcast but the router isn't the best (often only have 1-2 bars in my bedroom and end up shutting off Wi-Fi completely when in my kitchen or family room because the signal is so weak). Also, I'm going to try changing the "Keep Wi-Fi on during sleep" mode to "only when plugged in".
