1. win465's Avatar
    I am having a problem every night i plug my nexus 5 to charge and then in the morning when i take it off the charger i look at the battery level and it instantly turns to 99%. Every morning when I take my nexus 5 off the charger the battery level drops to 99%. Why does this happen? why doesn't my nexus 5 want to stay at a 100%?
    11-12-2013 01:02 AM
  2. N4Newbie's Avatar
    They all do that; the Nexus 4's do it also.
    Could just be the rounding algorithm; maybe 99.999% rounds DOWN to 99% rather than UP to 100%. If that is the case, the phone could never remain at exactly 100% for more than a second or two.
    win465 likes this.
    11-12-2013 01:12 AM
  3. win465's Avatar
    ya but it just frustrating looking at a new phone do this.
    11-12-2013 01:14 AM
  4. turbodmac's Avatar
    Seriously? Find something else to complain about!
    cgardnervt, Kamin, ras.cal and 3 others like this.
    11-12-2013 06:30 AM
  5. cgardnervt's Avatar
    +1! Its nothing new. Even my HTC One does this.
    11-12-2013 06:37 AM
  6. Robbie317's Avatar
    Miine usually says "Charged" when I pull it off the charger and then it will drop to 99 maybe a minute or two after it's been off the charger, every phone I've ever owned after a week or so it will drop to 99 rather quickly, the original EVO 4G use to go from straight off the charger to 90%.. lol.. Damn you Wi-Max... I don't plug mine up I am using the older Nexus 4 wireless charging hockey puck (I can't imagine that makes a difference, although it does charge faster via Qi vs USB?? This thing has a SLOW charge when hooked on the USB charger)
    NexusNick123 likes this.
    11-12-2013 06:44 AM
  7. GoBigRed79's Avatar
    When your phone hits 100% it stops charging to avoid overcharging the battery. It will drop to 1% or 2% before topping it off again. This is normal for almost all phones.
    11-12-2013 07:57 AM
  8. JonK's Avatar
    Estimating the energy left in a battery is an extremely imprecise science. Generally above 90% it is very difficult to tell what the actual charge is. That is why some phones stop charging anywhere between 90 and 100. Thats also why some phones seem to die from 100-90 very quickly.
    11-12-2013 08:04 AM
  9. snoopyandroid's Avatar
    1st world problems.
    11-12-2013 09:00 AM
  10. tippmann15's Avatar
    This is normal op, if it ever says 100 for a long time your system is messed up.
    Note 3
    11-12-2013 09:08 AM
  11. Infinity's Avatar
    This. No phones keeps charging the entire time it's plugged in - and you wouldn't want it to.
    11-12-2013 09:12 AM
  12. clevin's Avatar
    this is not what OP was asking.
    11-12-2013 09:15 AM
  13. turbodmac's Avatar
    In all seriousness, how many days/cycles do you have on your battery? Mine does actually stay at 100% until I get a bit of screen use and it updates.
    It dropped to 99% after BTing the screenshot to my Mac...
    11-13-2013 05:39 AM
  14. SeanBlader's Avatar
    Careful what this guy says, he's obviously an Apple Fanboy. ;-P
    On topic though, OP, I think you should get rid of that POS phone and get a new one. I think I might be able to manage with a phone that only charges to 99%, I mean it will be a terrible struggle to get through the day, and I'll probably be exclaiming FML a lot, but for you, I think I'll take that hit. Seriously, PM me and I'll get you my address where you can ship your little turd.
    turbodmac likes this.
    11-13-2013 09:57 AM
  15. Adamsberg's Avatar
    Exactly the cause for the % behavior
    Android phones of the first generation showed this dropping while charging.
    But this confused the user ... and now, when our phones reaches 100% then they stay on showing 100%.
    So if your phone has really 99% but shows 100% and you unplug it, then it will show its real 99%
    11-13-2013 01:45 PM
  16. NexusNick123's Avatar
    I get 15-17 Hours of battery with my N5 and I'm happy with that.. I never noticed if mean did this but even if it does if you get a full day battery why let it bother you.. Just saying not trying to be rude..
    11-13-2013 02:06 PM
  1. Too late to get a Moto X?
    By andog88 in forum Moto X (2013)
    Last Post: 04-27-2014, 08:33 PM
  2. N5 battery down to 58% overnight, normal?
    By 6packer in forum Google Nexus 5
    Last Post: 11-15-2013, 02:15 AM
  3. Replies: 0
    Last Post: 11-12-2013, 12:56 AM
  4. Period to sync email - what does "Automatic"mean?
    By ipapartners in forum General Help and How To
    Last Post: 11-12-2013, 12:14 AM
