1. hutchmanz's Avatar
    Hello everyone,
    I received my Nexus 5 yesterday and can't seem to get the LED notification light to function. Pulse Notification light is checked in settings. It doesn't light at all when an email or text is received or even when its plugged in charging.
    Any help greatly appreciated.
    Thanks.
    11-19-2013 01:23 PM
  2. unashamedgeek's Avatar
    Try downloading Light Flow free version just to test and make sure the LED works at all.
    11-19-2013 01:27 PM
  3. hutchmanz's Avatar
    Thanks, I just tested it with light flow "enable LED's test" and nothing.
    I guess its a defective device.
    Thanks again,
    11-19-2013 01:38 PM
  4. unashamedgeek's Avatar
    If in the main phone settings, you enabled the LED and if you enabled Light Flow in the Notifications area and it still won't work, I would give Google a call and see if they have a trouble shooting idea or get yourself in for a new device.
    11-19-2013 01:54 PM
  5. VoltaicShock's Avatar
    I am having the same issues with the LED. Sometimes it works and other times it does not.
    12-23-2013 01:23 PM
  6. benhmadison's Avatar
    Hello everyone,
    Thanks.
    Factory reset. If that doesn't work then it is defective.
    12-23-2013 01:31 PM
  7. gidgiddonihah's Avatar
    ^^ This. When you call for a replacement they may have you test it a way we can't think of, but with a factory reset it would be dead.
    Sent from my Nexus 5 using Tapatalk
    12-24-2013 11:58 AM
  1. Replies: 7
    Last Post: 11-22-2013, 08:55 AM
  2. Nexus 7 connection
    By allyg77 in forum Google Nexus 7 Tablet (2012)
    Last Post: 11-20-2013, 11:37 AM
  3. 2012 N7 won't connect but 2013 N7 will
    By davidwright5014 in forum Google Nexus 7 Tablet (2012)
    Last Post: 11-19-2013, 02:07 PM
  4. WTS Nexus 5 16gb Black
    By jev425 in forum Marketplace Archive
    Last Post: 11-19-2013, 02:02 PM
  5. Why can some apps work around corporate pin lock and some can't?
    By tanyet in forum Samsung Galaxy Note 3
    Last Post: 11-19-2013, 01:16 PM
