1. Yogi217's Avatar
    Trying to side load 4.4.1
    I get stuck on the droid with red exclamation point. I try pressing vol up and power nothing happens. I want to get to stock recovery mode.
    Following these instructions and stuck on step 14. http://www.droid-life.com/2013/02/12...stom-recovery/
    12-06-2013 08:14 PM
  2. y2whisper's Avatar
    Sounds like you are in Stock recovery. Press the power and volume up buttons when you hit that screen.
    12-06-2013 08:24 PM
  3. Yogi217's Avatar
    Did that and nothing happens
    Just reboots after a bit.
    12-06-2013 08:27 PM
  4. Yogi217's Avatar
    12-06-2013 09:14 PM
  5. yfan's Avatar
    Congrats on figuring it out! Now you will never have to wait for an OTA to come crawling to your phone!
    12-06-2013 09:38 PM
  6. Yogi217's Avatar
    Why did I not do this before?? You are so right. After doing this, I am never waiting for an update again!!
    So cool.
    Now I plan to learn how to root over the next few weeks...
    yfan likes this.
    12-06-2013 09:49 PM
  7. slave's Avatar
    12-06-2013 11:28 PM
  8. JohnnyBroccoli's Avatar
    I'd like to side load 4.4.1 on to my brand new Nexus 5 as well. Completely new to Android and side loading though. I think I understand all of the steps but I don't get how to navigate to a particular folder via Terminal on a Mac. Any help would be appreciated.
    Otherwise how long would you guess it might take for this thing to come OTA?
    Thanks.
    12-07-2013 01:15 AM
  9. QWIKSTRIKE's Avatar
    Thanks.
    There is a thread on XDA on how to manually update the Nexus 5, and people with Macs are there doing this! Anyone with a window based PC will find a post that I made there which helps sort out installation bugs incurred while in recovery!
    Yogi217 and JohnnyBroccoli like this.
    12-07-2013 08:31 AM
  10. srkmagnus's Avatar
    Thanks.
    When you installed the SDK you should have chosen the location you wanted to save it. So navigating to it would look like this when you have the Terminal App open:
    Code:
    cd location/of/sdk/file/platform-tools
    If you are unsure, just right click on the platform-tools folder and select properties. In the window that pops-up you will see the file location. Copy the whole location and paste it after "cd". The update file needs to be put in the platform-tools folder in order to work.
    Let us know if you have further questions.
    JohnnyBroccoli likes this.
    12-07-2013 02:22 PM
  11. Yogi217's Avatar
    I used the adb not the cd command and it worked for me. I got stuck on the red exclamation point, but figured it out and then it was smooth sailing after that.
    Sent from my Nexus 5 using Tapatalk
    12-07-2013 03:44 PM
  1. Help, GS4 stuck in Boot
    By Andre Hebra in forum Verizon Samsung Galaxy S4
    Last Post: 01-12-2014, 08:25 PM
  2. help motomaker upgrade without losing unlimited
    By bellringa in forum Moto X (2013)
    Last Post: 12-06-2013, 10:06 PM
  3. Need help or OTA pacakge zip for 4.2.2 update - DNA on t-mobile
    By poots1101 in forum Verizon Droid DNA
    Last Post: 12-06-2013, 08:47 PM
  4. Need help/recommendation on buying a backup phone...
    By sunrat39 in forum General News & Discussion
    Last Post: 12-06-2013, 07:21 PM
  5. Need Help! Brand New Right of Box Root Went Bad!
    By fish411 in forum Nexus 5 Rooting, ROMs, & Hacks
    Last Post: 12-06-2013, 07:12 PM
