1. emcee squared's Avatar
    Hello, folks.
    I'm a proud and happy owner of a Nexus 5, but have an odd quirk. I'm rooted with the stock ROM and Trinity Kernel (which I think may be the culprit, I'm not going to read 1,000 responses on a thread in a different forum to find out). To my problem: whenever the phone is off and plugged in my laptop's USB port or the travel/wall charger, the initial charging icon that shows the battery's level does not disappear. Even when I have unplugged the charger, the icon stays until I boot up the phone. Do any wise folks on here have a suggestion aside from a factory reset? I've tried a few things already, but do hit me with ideas.
    12-07-2013 05:19 PM
  2. srkmagnus's Avatar
    I'm bootloader unlocked, rooted with stock kernel and when I power+plug charger into wall outlet the battery charging symbol is there. It goes off about 10-15 seconds afterwards and will re-appear when I press the power button. I think this is pretty common with all android devices while powered off and charging.
    Are you saying the screen never turns off and the symbol is on the screen the whole time (until reboot)?
    12-07-2013 09:50 PM
  3. emcee squared's Avatar
    Correct.
    12-08-2013 06:16 AM
  4. srkmagnus's Avatar
    Correct.
    Yes, it might be related to the kernel. I'm not sure why that would be and don't think a factory reset will clear it - though, it doesn't hurt to try if you are up to backing-up your data.
    12-08-2013 03:06 PM
  5. emcee squared's Avatar
    I'll try some other things. It isn't a huge deal, just slightly annoying if I want to charge quickly.
    12-08-2013 08:49 PM
  6. srkmagnus's Avatar
    Another quick way is to test with stock kernel (if you have a backup) or install Franco's kernel.
    12-09-2013 09:43 AM
  7. Huang Huang's Avatar
    Hi I have the same problem. Did you solve it? Thanks!
    03-25-2014 01:35 AM
  1. Battery Drain!!
    By barbow in forum Samsung Galaxy S3
    Last Post: 12-15-2013, 08:22 PM
  2. S pen is different in my Galaxy Note 3
    By Tazlim in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-08-2013, 06:59 AM
  3. Very Top left of screen icons
    By androidagatha in forum Samsung Galaxy SIII I9300
    Last Post: 12-07-2013, 10:06 PM
  4. Replies: 3
    Last Post: 12-07-2013, 07:55 PM
  5. Is camera zoom optical or digital?
    By Ocoee in forum LG G2
    Last Post: 12-07-2013, 04:18 PM
