1. bmaster7's Avatar
    I have been having some weird issues with my phone. Sometimes when I recieve a call the phone rings but the screen will not turn on. Also some other random issues. I am stock and not rooted. Usually a reboot fixes the issues. Anyone else with strange things going on.
    Absolutely love the phone though!!
    12-12-2013 11:17 PM
  2. Eclipse2K's Avatar
    Try and go to Settings > Apps > All > Phone > Clear Data and Cache.
    Sent from my XT1080 using Tapatalk
    12-12-2013 11:27 PM
  3. bmaster7's Avatar
    Thanks! I will let you know if the issue persists.
    Eclipse2K likes this.
    12-12-2013 11:55 PM
  4. briansenk's Avatar
    Am having a similar problem with my phone. it doesnt load contacts and shows no call logs. am using android phone, model number I9500, Adroid version 4.2.2. help pliz.
    have tried to kill all running applications under
    Settings > Apps> Running
    its still not working
    08-03-2014 04:48 PM
  5. Anant Bharadwaj's Avatar
    my phone dialer is not working properly i m able to receive calls and talk but m unable to dial any contact ...... for instance i dial a number it displays a message dialing and the call ends on its own without even ringing ..... plz help asap cause m unable to call anyone and my phone model is micromax canvas nitro a311
    07-31-2015 10:26 AM
  6. Sayed Alishah's Avatar
    i also have same problem
    08-06-2015 01:13 PM
  7. funkyrohit29's Avatar
    (email address removed by Moderator)
    my phone dialer is not working properly i m able to receive calls and talk but m unable to dial any contact ...... for instance i dial a number it displays a message dialing and the call ends on its own without even ringing ..... plz help asap cause m unable to call anyone and my phone model is micromax canvas Sliver 5
    Please let me know the solution
    07-03-2016 03:24 AM
  8. dpham00's Avatar
    Mod Note, Please do not post your email address on this public forum
    07-03-2016 03:36 AM
  9. cordaniel mcbryant's Avatar
    Im having the problem with my phone but when i try to dail out i get "No application can perform this action Enable Disabled built-in application?" i factory reset my phone and still nothing.. I have a lg k7 rooted can someone please help me with this situation?? I called my phone to see if it would work and the phone didnt even ring
    09-05-2016 09:00 PM
  10. Bhaskar Barik's Avatar
    09-08-2016 05:45 AM
  11. Bhaskar Barik's Avatar
    my phone dialer is not working properly i m able to receive calls and talk but m unable to dial any contact ...... for instance i dial a number it displays a message dialing and the call ends on its own without even ringing ..... plz help asap cause m unable to call anyone and my phone model is micromax AD3520
    09-08-2016 05:52 AM
  12. Bhaskar Barik's Avatar
    09-08-2016 05:54 AM
  13. Bhaskar Barik's Avatar
    [email removed by Mod]
    09-08-2016 06:00 AM
  14. vinay87's Avatar
    I am having same problem pls help me....
    09-08-2016 11:37 PM
  15. dsanchari279's Avatar
    my phone dialer is not working properly. I trying to open it but it not open and also show ing.. unfortunately dialer has stopped. plz hlp me. even I reboot and clear data!!
    11-14-2016 11:36 PM
  16. Ghanshyam Tourmasti Travels's Avatar
    my phone call / dialer app is not working. im using intex aqua s7.
    also i did clear cache & clear data after this thing its not working what should i do.
    01-04-2017 12:57 AM
  1. Am I the only DNA user with no update?
    By gig93 in forum Verizon Droid DNA
    Last Post: 12-22-2013, 01:13 AM
  2. Audio Problem
    By Felipe Van Der Donckt in forum Samsung Galaxy SIII I9300
    Last Post: 12-17-2013, 03:02 PM
  3. Google Search update and GEL
    By ajkam in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-14-2013, 07:14 AM
  4. Connecting to Wifi with a login page.
    By Madzmadz13 in forum Google Nexus 7 (2012) Rooting, ROMs, & Hacks
    Last Post: 12-13-2013, 08:35 PM
  5. 4.4.2 nexus 5 camera flash greyed out even with HDR+ off
    By myusernam in forum Android 4.4 KitKat
    Last Post: 12-13-2013, 03:35 PM
