Results 1 to 16 of 16
    Default How To Use Nexus 5 As a Remote Controller
    Heard that it can be used as a remote controller. Which app is best? Do you need to set it up?
    As soon as my N5 arrives I want to try even this function!
  2. #2
    EviI's Avatar
    Posts
    Carrier
    Stock 4.4.2 KitKat
    Default Re: How To Use Nexus 5 As a Remote Controller
    A remote controller for which device?
  3. #3
    using android devices as a remote control for TV, audio, lighting, etc... can all be done, but how one does that is very much dependent on what device/devices you want to control. In many cases, this will require additional hardware.
    The general exception to that rule (requiring additional hardware) is if you are trying to control another device that is network enabled, and you can find an app from the manufacturer of that other device.
    Quote Originally Posted by oberkc View Post
    Thought to control TV and dvd player.
  5. #5
    Quote Originally Posted by AndroidDario View Post
    You may be thinking of IR support which the N5 does not have.
  6. #6
    Works great with BubbleUpNp app to control my DLNA wireless home entertainment system!
    Also works with TV Side View app to control my SONY Blueray player & access TV Guide.
    Heard it has IR.
  8. #8
    Heard it has IR.
    Heard wrong.
  9. #9
    There is no IR on the Nexus 5. However I have Comcast that has the Xfinity App that I can use my Nexus 5 to change channels and even record TV shows on my Xfinity DVR. Also has XFINITY TV Go to stream TV shows and movies from premium channels like HBO, Starz, Showtime, Cinemax and cable channels like TNT, TBS, Cartoon Network, A&E, AMC, WETV, Food Network and HGTV.
    Check your TV cable or service provider to see what Apps they have in Play Store.
  10. #10
    This depends on brand, model, etc.
    If internet enabled, there might be an app for both devices.
    If not, you would have to make a choice about what hardware you want to use to transmit IR. I use a global cache WF2IR. I think there is still a device called redeye. Also, Logitech still sells the ultimate hub. There are probably others. Unfortunately, there is no IR built in, so you need additional hardware.
    Apps for control will vary, depending on hardware chosen.
  11. #11
    I just bought the iTach Wifi to IR (WF2IR) and set it up. Now I am trying to figure out which app to use on my Nexus 5 for control... which do you use for control? My setup is quite simple... TV, Apple TV, and Bose Sound.
  12. #12
    any app for my nexus 5 to use as remote control for my android tv
    Thx
  13. #13
    Google Nexus 5
  14. #14
    Quote Originally Posted by Afroz Khan2 View Post
    Google Nexus 5
    Thanks for that insightful, well thought out first post. You are already a legend.
  15. #15
    Please let me know how to use Nexus 5 as TV remote
  16. #16
    Quote Originally Posted by Gazala Faruqui View Post
    You can't. It does not have IR support like a regular remote has.
  1. Google Nexus 7 (2013) Anyone able to send SMS messages on Verizon?
    By diesteldorf in forum Google Nexus 7 (2013) Rooting, ROMs, & Hacks
    Last Post: 02-06-2015, 06:50 AM
  2. What to do if your phone is stolen?
    By emiinn in forum Samsung Galaxy Note 3
    Last Post: 12-23-2013, 11:52 AM
  3. Proximity Alarm - alternatives to MI-Zone
    By stain356 in forum General News & Discussion
    Last Post: 12-15-2013, 05:34 PM
  4. Unable to connect the internet via usb cable
    By inbadas in forum General Help and How To
    Last Post: 12-14-2013, 10:25 PM
  5. Google Now not available on some Nexus 5 devices?
    By mrsmumbles in forum Google Nexus 5
    Last Post: 12-14-2013, 04:47 AM
