How To Show Battery Percentage
JohnnyBroccoli
419
What about Battery Percentage for KitKat, develoled by XDA Developer?
It's better than nothing but you can't really see the reading until you're down below 45% or so. I'd like to find a better alternative as well. Don't like using the Battery Doctor one because it just doesn't look clean.
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
System settings > Battery is all I need :). Otherwise, two finger slide down from top as mentioned above to have the tiles show in the notification area.
zedorda
2,594
178
I have used this app with all my devices. Even tho it has not been updated since 2010 it still works fine. I like to save apks to my own server since some updates from the play store have broken perfectly good apps in the passed. Its just a widget to show basic system parameters and acts as a shortcut to the related settings section.
Play store doesn't list it as compatible with much since it hasn't been updated so I attached the apk. Just use a file manager like X-plore to install.
  • System Info Widget_2.2.apk
p3ntyne
265
What do you mean by 'not clean'?
