Results 1 to 19 of 19
Like Tree3Likes
  • 2 Post By dubya.t
  • 1 Post By GLHRonin
    dubya.t's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Nexus 5 Camera Auto Focus does not work
    My camera's auto focus is nearly non existent.
    I sit there waiting for a picture to be non blurry for sometimes up to 5 minutes. QR Scanner will NOT focus.
    Anyone have this problem or have a work around other than factory reset? Running 4.2.2..the update that was supposed to fix this seemingly made it drastically worse for me.
    sfbates and vancitypharaoh like this.
  2. #2
    Disturbed_Angel's Avatar
    Posts
    Global Posts
    501 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Nexus 5 Camera Auto Focus does not work
    What kind of conditions does this occur, or is it all the time? Also, what settings are you using for the camera? Finally, not trying to be rude, just want to check all the boxes, is the lens clean?
    dubya.t's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Lens is clean, I checked this as well.
    HDR+ or non HDR it does this all of the time. Standard settings when non HDR.
  4. #4
    Posts
    Global Posts
    501 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    And you say that it will search for extended periods even after you hit the shutter button?
  5. #5
    jiggyb21's Avatar
    Posts
    Global Posts
    195 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have I believe the same problem. On 4.4.2... The focusing issue occurs for me in low light, but not that low. I have a multitude of other devices all of which do just fine. Pretty frustrating...I understand it's a phone camera but it's the only phone I've ever had that won't at least attempt a shot. I tap the screen and the phone does it's thing, it looks to be in focus but right at the moment you're for the green circle it either just stops or it tries again.
  6. #6
    Brian Low's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No problems with my camera's auto focus when using regular and HDR+. I get auto focus problems when i am in video recording though. It doesn't even try to focus. It just stands there and im stuck with a blurry video.
  7. #7
    greydarrah's Avatar
    Posts
    Global Posts
    5,991 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I only have this issue when trying to focus on certain things, like something that blends in very well with the background. It doesn't happen often, Have you tried any other free camera apps like Camera FV-5 lite, Camera Zoom FX, Vignette Demo...
  8. #8
    sfbates's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine seems improved after the update.
    Perhaps try using ProCapture camera or Camera Zoom FX.
    This would at least help you figure out if it is a issues with just the Google camera app or maybe a hardware issues with a bad lens?. Worth a shot.
  9. #9
    srkmagnus's Avatar
    Posts
    Global Posts
    13,764 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    No issues here with mine. Perhaps go into Settings - Applications - camera and clear the cache? Can you also take a picture as you normally would and post it for us to see?
  10. #10
    GLHRonin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    mine doesn't even focus, picture is just blurred and doesnt change while the auto-focus icon spins... can this be an hardware faliure?
    (oh and I am running 4.4.2)
    vancitypharaoh likes this.
  11. #11
    vancitypharaoh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GLHRonin View Post
    Mine is the EXACT same. Thought I was going crazy cuz didn't know if my phone was just a faulty POS
  12. #12
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Have you found an answer yet as to how to fix it?
    My front camera is super clear but my main camera is blurry beyond belief. The auto focus is not working at all
  13. #13
    Vikram Bajaj's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ya...mine too!
    It usually takes amazing snaps, but sometimes, the auofocus doesn't work.At all.It keeps switching from blurred to clear to blurred, like it's struggling to take a pic.Hope the next update adresses this issue
  14. #14
    GLHRonin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by vancitypharaoh View Post
    mine is still messed up I don't know what to do....
    Quote Originally Posted by Vikram Bajaj View Post
    Ya...mine too!
    yeah but our problem isn't like this the camera NEVER focus NEVER..
    has anyone fixed this yet????
  15. #15
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So... My camera just updated with some new features but it still takes blurry pics
  16. #16
    logicalor's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    FYI I have had the same issue on my Galaxy S4 for about a month. No idea why. I am guessing it's some sort of interface problem - surely it can't be a coincidence that it's affecting a bunch of people.
  17. #17
    Acwalter's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I never had a problem, through all releases, including L. Just got a replacement device from Google and I am having this same issue. The phone is a factory referb, just turned it on and this was the condition. Bar codes are so blurry they wont read, photos are blurry. The phone I returned did not have this problem so I am thinking it is hardware not software. I notified Google support, we'll see what they say.
  18. #18
    5oonN6's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I did factory reset and AF started working!!
  19. #19
    morgainebrigid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Smile Re: Nexus 5 Camera Auto Focus does not work
    I uninstalled the last app I'd installed, rebooted my phone, and the camera focuses fine now.
  1. LG G2: GPS stopped working & possible update soon
    By Christopher Senn in forum Verizon LG G2
    Last Post: 09-07-2014, 09:29 PM
  2. My camera is now screwed
    By SCjRqrQCnBQ19QoYCtdl in forum HTC One M7
    Last Post: 04-18-2014, 11:38 PM
  3. Unable to Get Flash Player Working Nexus 10 KIT KAT
    By vienna01 in forum Google Nexus 10 Tablet
    Last Post: 02-05-2014, 11:09 PM
  4. Kindle App on AT&T Note 2 phone not working
    By ccagte6 in forum AT&T Galaxy Note 2
    Last Post: 01-06-2014, 04:54 PM
  5. Android update stops before end on Nexus 7 tablet ?
    By LaQira in forum General Help and How To
    Last Post: 01-03-2014, 01:20 AM
