Results 1 to 5 of 5
    Default Will the Galaxy S4 cables work on my Nexus 5?
    So I have decided to make the switch from a Galaxy S4 to a Nexus 5. Unfortunately I just spent a small fortune on the Samsung website buying a bunch of accessories for my Galaxy S4, including a car charger and an extra wall charger for when I'm at work. My understanding with the Galaxy S4 is that although they are technically microUSB, Samsung had done some sort of slight modification and that it was simply better to use official Samsung cables. I didn't have the energy to really verify this as you might be able to tell so I just went with it. I would like to know, in short, whether my Galaxy S4 chargers will work for my Nexus 5 or not.
  2. #2
    ezcats's Avatar
    Posts
    Global Posts
    34 Global Posts
    Default Re: Will the Galaxy S4 cables work on my Nexus 5?
    Quote Originally Posted by Paolo Bergantino View Post
    So I have decided to make the switch from a Galaxy S4 to a Nexus 5. Unfortunately I just spent a small fortune on the Samsung website buying a bunch of accessories for my Galaxy S4, including a car charger and an extra wall charger for when I'm at work. My understanding with the Galaxy S4 is that although they are technically microUSB, Samsung had done some sort of slight modification and that it was simply better to use official Samsung cables. I didn't have the energy to really verify this as you might be able to tell soI just went with it. I would like to know, in short, whether my Galaxy S4 chargers will work for my Nexus 5 or not.
  3. #3
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    It'll work fine. Obviously it's recommended that you use the stock charger but unless you have issues with it, I'd keep using that one
  4. #4
    The Lg ones are complete crap. My cable already ripped and i used it maybe 3 times (i was using another usb cable since the beginning).
  5. #5
    I use whatever charger I pull out of the drawer without issue. I use Samsung cables when connecting to my PC at home or at work. Just remember the Nexus 5 USB port is backwards.
  1. Anybody send in their Nexus 7 to Asus for warranty repair?
    By CarbonOak in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-04-2015, 08:03 PM
  2. Cant "unlock" the screen sometimes
    By DoMiNo87 in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-21-2014, 04:01 PM
  3. Droid MAXX: car issues..phone works but not media
    By Adam21221 in forum Motorola Droid MAXX
    Last Post: 01-17-2014, 07:32 PM
  4. My battery is not all that good
    By emscapt47 in forum Samsung Galaxy S4
    Last Post: 01-16-2014, 08:53 PM
  5. Can't get any version of Kit Kat to flash to my Boost Mobile S3.
    By Thomas Zimmerman in forum Sprint Galaxy S3
    Last Post: 01-16-2014, 08:03 PM
