01-24-2014 08:38 PM
29 12
tools
  1. Troothdotcom's Avatar
    so today was my first day of real world use with my new Nexus 5 and it gave me 13+ hours of battery... in your own experience does this sound about right or will my battery start dying quicker. just a little more info i have all the same apps i had on my Nexus 4 and used daily and only got about 7.5 hours on that. as you could tell im thrilled if things stay like this.
    01-20-2014 10:31 PM
  2. UJ95x's Avatar
    Depends on how you use it. It should be pretty consistent as long as your usage patterns stays the same or similar.
    After a few months the battery will start to deplete because of all the charge cycles, but for now I'd expect around that or better while the OS and battery "settle in"
    01-20-2014 10:38 PM
  3. jtb79's Avatar
    That's about what I get with above average usage. I have no problem getting thru a day, especially since I flashed the cataclysm ROM. It really seemed to make a difference for whatever reason.
    01-20-2014 10:38 PM
  4. UJ95x's Avatar
    The kernels in custom ROMs are usually a lot better than what Google gives.
    Improves idle time significantly in some cases
    01-20-2014 10:49 PM
  5. bembol's Avatar
    If today's Super Phones can't give you at least 12 hours they need to get their act together.
    Very happy with my nexus 5!
    djr7572 and ChuckG73 like this.
    01-20-2014 10:49 PM
  6. sheppy1's Avatar
    My nexus 5 gives me just over that every single day and I have everything turned on including Bluetooth for most of the day too. I also send lots of texts and make around 2 hours of calls. Very impressed as my iPhone 5 lasted only 7 hours with the same usage!
    Sent from my Nexus 5 using Tapatalk
    01-21-2014 02:21 AM
  7. anon(4903109)'s Avatar
    My nexus has given me terrible battery life the last couple of days with average usage... So I switched to cyanogenmod. Will see how it works out.
    Yesterday's battery usage: 100% to 14% in 6hrs 1min.
    01-21-2014 05:49 AM
  8. Shocktribe's Avatar
    I carry a portable charger... I think that says everything
    01-21-2014 09:11 AM
  9. flick0416's Avatar
    That's pretty typical for me. I normally get at least 15 hours out of mine. I've gone over 30 hours multiple times.
    01-21-2014 11:34 AM
  10. srkmagnus's Avatar
    Battery will definitely start to settle in. Stock, there's not much to push in terms of squeezing out more battery life aside from adjust sync, screen brightness, etc. The big improvement comes from being rooted and installing a Kernel developed with battery life in mind.
    01-21-2014 04:47 PM
  11. anon(4903109)'s Avatar
    Hey guys I wanted to post an update regarding my battery life issues... I installed CM11 and started fresh... I have all of my apps reinstalled and used my phone no differently than average
    Here are the results
    That's right! 91% after 6.5hrs!
    srkmagnus likes this.
    01-21-2014 06:07 PM
  12. ankit717's Avatar
    Best way to extend battery is root the phone and use few apps such as greenify, baytery doctor. And you are looking at about 20+ hours off full charge with 3+ hours of screen time.
    01-21-2014 07:11 PM
  13. UJ95x's Avatar
    I think flashing a different kernel is better for battery. Idle drain improves a lot, that's what makes the biggest difference aside from changing screen brightness
    01-21-2014 07:22 PM
  14. srkmagnus's Avatar
    http://img.tapatalk.com/d/14/01/22/dereqa5y.jpg
    Cool. Looks like he clean install helped. What's your screen on time?
    If you are happy and see the improvement then that's what matters most. :-)
    01-21-2014 09:53 PM
  15. Almeuit's Avatar
    It looks like you had data off.. I'm also curious what is your screen on time?
    I am curious about the battery when using the functions of the phone versus turning it all off .
    Sent from my T-Mobile Note 3 using AC Forums.
    01-22-2014 04:31 PM
  16. anon(4903109)'s Avatar
    when I took that screen shot I accidentally shut off data moments before
    01-22-2014 04:51 PM
  17. Dave Clark's Avatar
    I am using my N5 as per normal and I am getting 15 hours with 50% battery charge remaining. That's calls, texts, email, facebook, G+, snapchat, playstation app, location on, art enabled, the list goes on. Very happy with battery life.
    ChuckG73 likes this.
    01-23-2014 05:07 AM
  18. Almeuit's Avatar
    Well.. What's the screen on time?
    01-23-2014 09:09 AM
  19. bagou01's Avatar
    I still don't really understand the fuss about battery life...
    i mean, i took this screenshot yesterday, after a normal work day : i phoned 5 times, i played ridiculous fishing, watched 9gag on the loo, etc... and see the result when going home : still more then 70% available battery
    Nexus 5: 13+ hours of battery-screenshot_2014-01-23-21-23-14.jpg
    what do you people do with your phone?
    Details: the screen is always set to max brightness, so no cheating here, and the location settings to precision, so no cheat either...
    Only tip, i disabled 4G, given that not only is the coverage a bit crappy in my region, but 3G is always fast enough so i don't have to wait for nothing either video or photo... so i don't see the point in 4G...
    01-24-2014 03:36 AM
  20. UJ95x's Avatar
    How much screen time is that? I'm guessing less than an hour
    I don't worry too much about battery but it should be able to get me through a full day, with more than 4 hours of screen time. Mine does a lot better than that
    01-24-2014 12:58 PM
  21. Gwaron's Avatar
    P
    According to the screenshot, about 2 hrs, 45 min. And a little over an hour playing the game.
    01-24-2014 02:05 PM
  22. UJ95x's Avatar
    P
    What makes you say that? The percentage of battery that has been used?
    01-24-2014 02:42 PM
  23. Gwaron's Avatar
    I was pretty good at math.....
    mrsmumbles likes this.
    01-24-2014 03:23 PM
  24. UJ95x's Avatar
    Yeah, but that isn't accurate. My phone is currently at 19 hours on this charge. My screen has used up 67% of the battery. I assure you I am nowhere near 12 hours of screen time.
    You can't just multiply the percentage and the amount of time the phone has been running...
    01-24-2014 04:33 PM
  25. Gwaron's Avatar
    Yeah, I see where you're coming from. When I've checked, it's usually been pretty close, but it may be how I use my phone. Thx for the edumacation
    01-24-2014 04:38 PM
29 12
  1. Samsung S3 external battery charger.
    By Ruben Gillette in forum Samsung Galaxy S III Accessories
    Last Post: 01-23-2014, 03:19 AM
  2. are battery saving apps good for nexus 7?
    By preppystud in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-22-2014, 07:07 PM
  3. cant turn bass of for internal spraker
    By Samir_Delic in forum HTC One X
    Last Post: 01-21-2014, 08:38 AM
  4. Google now battery drain?
    By mgloss in forum Verizon Galaxy S III
    Last Post: 01-20-2014, 09:27 PM
  5. How to I get rid of this popup?
    By DaRoni in forum Samsung Galaxy S4
    Last Post: 01-20-2014, 07:15 PM
