1. Stillhackin's Avatar
    First post here so hello everybody. I'm posting this hoping it may help others. For two weeks I have tried different settings to get my MMS working on Straight talk but nothing has worked. I finally called them and my settings I had were all correct except I did not have the words "Straight Talk" capitalized for the apn's name. We changed that and deleted all other apns then restarted my phone and now I have MMS working. I got the rest of the settings from straight talks website.
    02-02-2014 11:50 AM
  2. jmiesse134's Avatar
    PLENTY of posts on this topic. Search is your best opportunity to find a solution. In a nutshell, order a 2nd sim and install it and transfer to that sim . Same as you did originall. Of course this fixes the recieve mms problem. Please elaborate on what specfically is going on . Can you send but not receive? Also take a screen shot of your APN settings. Then we can tell you if they are correct.
    Also see this thread- MMS and Straight Talk Cant receive
    02-02-2014 04:49 PM
  3. twitchthecat's Avatar
    "PLENTY of posts on this topic. Search is your best opportunity to find a solution. In a nutshell, order a 2nd sim and install it and transfer to that sim . Same as you did originall. Of course this fixes the recieve mms problem. Please elaborate on what specfically is going on . Can you send but not receive? Also take a screen shot of your APN settings. Then we can tell you if they are correct."
    I tried a second SIM card and it did nothing to fix my inability to send or receive MMS messages on an HTC One, ATT SIM. Any other suggestions?
    03-04-2014 08:27 AM
  1. Why so much hate for Touchwiz?
    By Carlo Villa in forum Samsung Galaxy Note 3
    Last Post: 04-26-2014, 09:02 PM
  2. Big video problems on my phone.
    By gurumonkey in forum Verizon Galaxy Note 2
    Last Post: 02-02-2014, 05:25 PM
