Results 1 to 4 of 4
    Default Nexus 5 Hardware - Volume and Power buttons
    Hello,
    got a new nexus 5 today, everything is fine, have 2 questions, please assist.
    1. Which kind of cover/casing is good and by the way, the screen guard is come by default.
    2. All buttons work properly and there is no sound If i shake/make calls, but I noticed one thing, I think there are not even(not perfectly flat), Is this normal as power button functions normally and second thing is when I hold the button, I can move the buttons up and down(small movement) and there is a very tiny sound. Any body experienced this ? Will putting a case solve this problem ?
    cheers,
    avs
  2. #2
    ChuckG73's Avatar
    Posts
    Global Posts
    1,576 Global Posts
    Carrier
    Stock
    Default Re: Nexus 5 Hardware - Volume and Power buttons
    I am sporting a Tech 21 case and they also sell a screen protector but it comes separately. As far as your second question goes, I do not understand the question. The power button makes a noise and moves up and down?
    Hi chuck,
    thanks for reply. I will rephrase my question, maybe I did not tell properly. If I roll over the power button in my finger(assuming that it should be fixed in position), I can sense that it moves forward and backward, If this does not help, maybe, I will just take it to service center and get it checked once.
    Tech 21 case is not available where I stay(in India), How about this one ? Which is better ? Nexus 5 Bumper Case or LG QuickCover for Nexus 5 or i-Blason Google Nexus 5.
    cheers,
    avs
  4. #4
    jj14x's Avatar
    Posts
    Global Posts
    1,027 Global Posts
    Carrier
    Stock
    Quote Originally Posted by Avinash Nag View Post
    Search for loose power button rattle on Nexus 5 hereand you'll see a LOT of posts referring to this. It can be irritating, but doesn't affect the functionality of the phone.
  1. Replies: 3
    Last Post: 02-08-2014, 04:33 PM
  2. Replies: 4
    Last Post: 02-03-2014, 12:42 PM
  3. Here is a fix for chromecast and broadcom wireless adapter
    By Todd J in forum Google Chromecast
    Last Post: 02-03-2014, 02:48 AM
  4. Root my Nexus 7 2012
    By katcha in forum Google Nexus 7 (2012) Rooting, ROMs, & Hacks
    Last Post: 02-03-2014, 01:58 AM
  5. Need Help Backlight, microphone, call and scratchy after less than 15 days
    By Antonio Trollollo in forum General Help and How To
    Last Post: 02-02-2014, 10:31 PM
