1. krifor03's Avatar
    I don't know if anyone else is having this issue, but when every I'm connected to USB power my phone lags really bad. At first I thought it was my kernel so I witched back and forth between the stock kernel and franco's R32. I realized it wasn't until I unplugged my phone that the responsiveness returned So has anyone else experienced something to this effect?
    PS the lag I'm talking about is VERY noticeable, random pauses when scrolling, inadvertent application starts, etc.
    02-03-2014 06:29 AM
  2. N4Newbie's Avatar
    Just to clarify, by "connected to USB power" do you mean connected to a PC or laptop, or do you mean connected to a standard charger brick with a USB cable?
    If the latter, are you using the stock charger brick and cable?
    02-03-2014 06:59 AM
  3. krifor03's Avatar
    ahh, my science is flawed. I forgot the check with my laptop. I was using an aftermarket 1A wall charger (away from home and the plugs are different here). When connected to my laptop, I have not lag issues. I would find it hard to believe (but still plausible) that an aftermarket power source could cause these types of issues. 1A out of the stock brick should be 1A anywhere else correct??
    PS with the aftermarket wall charger my phone charges WICKED fast.
    02-03-2014 07:29 AM
  4. Caleb Pelton's Avatar
    Wall plugs are different? Are you in a place where they use 220 power?
    02-03-2014 07:36 AM
  5. krifor03's Avatar
    both 220-240 and 110-120
    02-03-2014 07:45 AM
  6. Caleb Pelton's Avatar
    OK. I was asking to ensure that the phone isn't plugged directly into a 220 outlet. I haven't looked at the specs on the phone, but they aren't usually made to go into 220.
    02-03-2014 07:55 AM
  7. krifor03's Avatar
    shouldn't be a problem regardless, the nexus 5 brick will take any power 110-240, the matter is the different countries use different shaped plugs. and the input doesn't matter as long as your output is 5V. I guess my question now is are there severe variances with the outputs some bricks display caused by some internal component
    02-03-2014 08:01 AM
  1. Unable to delete the folder created on app page in my Samsung Note 3
    By Krishna Naik in forum Samsung Galaxy Note 3
    Last Post: 02-25-2017, 11:22 AM
  2. Replies: 3
    Last Post: 02-08-2014, 03:33 PM
  3. Full conversion to GPE, 2 questions
    By purpleparrotuk in forum HTC One Rooting, ROMs & Hacks
    Last Post: 02-04-2014, 09:52 PM
  4. Rooting A Phone...But Swapping To A New Phone. #simcards
    By Missing_Linkz in forum General Help and How To
    Last Post: 02-04-2014, 12:03 AM
  5. Nexus 5 Hardware - Volume and Power buttons
    By Avinash Nag in forum Google Nexus 5
    Last Post: 02-03-2014, 03:32 PM
